Question about Whirlpool Dryers
Dryer gets hot and a fuse keeps burning out model number le577oxwno
  • 706 Answers
If you are referring to the FUSE in your house service panel and that IT keeps blowing, then you may have a loose cord wire at the dryer or mating receptacle. Always remove or disable power form these wires BEFORE performing any service. If you can extend the dryer away from the wall and examine the terminal block where the cord ( with ring lugs) is tied to it..check for any sign of carbon ( which would indicate a high impedance junction) meaning that it will get hot and may cause a fire.. Remenber, always remove or disable power from this circuit prior to working on it.. Good luck.. and hope this helps..
Posted on Sep 07, 2008
Electric lift stopped 2/3 way up. There was also a burning smell. Won't work at all. Is there a manual overide?
Hello;
My name is Peter. I am a retired field service appliance technician.
There is no manual override on your dryer. Which is a good thing.
You do not want to run your dryer at this point.
The burning smell is burning lint. Your dryer is plugged up with lint. This is a dangerous situation. You could burn down your home.
Your dryer will not run because the dryer fan will shut down if the air flow is obstructed.
You have a hot air exhaust manifold where the hot air goes into a round bottom inlet up to a expanded hot air distribution headed into the dryer. This is usually plugged up.
This may also have caused the fuse to blow, a operating switch or high temperature limit switch to fail.
Go into the following website and put in your model number. You will get diagrams and component part numbers. Your model number is located on a label either on the face of the dryer when you open the door or on the side of the door.
Water Filters Lawn Garden Appliance Parts
Mar 10, 2016 | Dryers
We put a new switch on our lid lock but it didn't fix d problem i
Hello Erikaadams;
You have not provided a model number. All dryers are different.
There are many components within the dryer that may keep it from running. You may have a fuse blown, but not knowing the model number I do not know it you have a fuse. Bad pressure sensor? The hot air distribution manifold plugged up with lint?
Go into the following link type in your model number and search the diagrams for switches, fuse........
Nov 23, 2014 | Washing Machines
Dryer not heating
Hello there and welcome to fixya
Here are the most common things that will need to be checked with a meter to ensure there is continuity on these parts no continuity means that the part is bad and needs replacement ok?
Thermal Fuse
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric solenoids which open the valve to let the gas flow into the burner assembly. If the dryer doesn't heat one or more of the solenoids may be defective. If the igniter glows for 90 seconds but the burner flame doesn't light, replace these coils as a set.
Dryer Igniter
If the dryer doesn't heat, the igniter might be burned out. Check the igniter for continuity with an ohm meter. Dryer igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can burn out over time. If the dryer doesn't heat, the element should be checked for continuity. The heating element cannot be repaired and must be replaced if defective.
Heating Element Assembly
The heating element assembly on an electric dryer can burn out over time. If the dryer doesn't heat, the element assembly should be checked for continuity. The heating element assembly cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the heat given off by the flame. If the dryer doesn't heat, the flame sensor might be defective. Check the flame sensor for continuity. This is not as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn't heat the high limit thermostat can be defective. It can be checked for continuity. If the thermostat is "open" the dryer doesn't heat.
Cycling Thermostat
The cycling thermostat regulates the temperature of the air in the dryer. If the dryer doesn't heat it may be caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at fault when the dryer doesn't heat. Check all of the other components in this troubleshooting guide before replacing the main control board. The main control board cannot be tested easily and must be replaced if it is defective.
Timer
The timer is normally not at fault if the dryer doesn't heat. In many situations where timers are replaced they end up being returned. Check all of the more common components in this troubleshooting guide before replacing the timer
Oct 14, 2013 | Amana Dryers
Stopped in mid cycle
Check your thermal fuse. The fuse will burn out if the dryer gets too hot. Take it out and test the fuse with a continuity tester. If it has no continuity the fuse if bad. If it is the fuse replace it and make sure the vent isnt clogged. That would keep the heat in and make the fuse burn up
Sep 24, 2013 | Whirlpool GEW9250 Electric Dryer
Dryer gets hot and shuts off
Check for airflow restrictions in the exhast hose. If the hose has lint or is restricted in any way the thermal fuse may burn out. Have a model number? Sea Breeze
Feb 28, 2013 | Dryers
Magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Magic Chef CYE2000 Electric Commercial...
Need to know were the fuses are located. the dryer runs but does not have heat.
Rathen than looking for fuses, it sounds more like your heating element is burned out.
Feb 07, 2010 | Kenmore Elite HE4 Electric Dryer
No hot air
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 15, 2009 | Dryers
Whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Jun 14, 2009 | Whirlpool Dryers
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
