Question about Zooper Zydeco Z344 Jogger
Zooper zydeco SL 398 - problem wheels
Hallo, I am at the end, i had constant problems with the wheels on the stroller, they keep falling off, there is no more warranty, because I purchased it last year, and there is only 4 month on the wheels. what shall i do, the stroller was not cheap and i have it just one year and it is falling apart, they said it is the mercedes of the strollers but I see it it quite cheaply made, especially the wheels. The wheels lock with a tiny wire and that wire is not working, did someone else had the same problem so you could help me? thank you very much Jana
SOURCE: how do i unfold a zooper tango double stroller?
There's a locking mechanism on the left hand side about mid-way down just under the armrest. You need to pull the plastic lock off of the pin and then unfold according to the "fold" instructions included in the manual.
Posted on Apr 19, 2008
SOURCE: Zooper walk air tire
You should be able replace it with a generic brand tube from Wal Mart- or any bike shop. Hope this helps!
Posted on May 04, 2008
momsjustknow
  • 135 Answers
SOURCE: broken front wheels on zooper double stroller
All is not lost yet, Contact Zooper directly to see if this can be fixed before throwing out your stroller.
info@zooper.com 1-888-742-9899 They have an online submission form on their website under the FAQ -"I have an older zooper stroller. How can I go about getting parts or service?" but when I went there, it seemed to be a warranty registration link instead.
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 127 Answers
SOURCE: how to clean zooper buddy stroller?
I always wash my stroller fabrics by hand soak them in water with little tide and rinse them and then hang them to dry.
Posted on May 18, 2009
  • 3 Answers
SOURCE: how to fold zooper kroozer jogging stroller
I believe that near the handle bar on either side there is plastic tubing over the metal section. You pull the plasticy bit up towards the handle bar - one has a metal lever under which you release (lhs I think) this then splits the side bars into 2 parts and in theory it drops down neatly
Posted on Oct 19, 2009
What are the red buttons for on the bottom of the Zooper Zydeco? also, can the seating be washed?
Everything comes off m ine for laundering but the sunshade:) Mine must be a different model year because I don't have red buttons on the bottom. The ones under the seat are used to turn the seat around:)
Jun 03, 2010 | Zooper Zydeco Z344 Jogger
Our zooper boogie red jogger stroller has had problems for a long time, the front wheel is very hard to push and lock, the whole stroller seems really hard to handle, it just wont turn or go where it needs...
Hi I had a similar problem with mine. I ended up just tightening the cable that connected the front wheel to the lock. (screw-like connector bolt under lock) You may want to adjust the cable as well sounds like it needs to be loosened maybe. I hope that I helped. Good luck! :)
May 03, 2010 | Zooper Boogie - Red Jogger Stroller
Needing to find a zooper zydeco 2005 manual...any ideas?
Have you gone to zooper.com? That is where my manual is printed from:)
Jan 24, 2010 | Zooper Zydeco Z344 Jogger
Have a flat tire and need to find a replacement
The easiest thing to do is go to a local bike shop ... bring the flat inertube to them... If you can bring it to one of the mom and pop stores usually you get better service and they know alot more than the huge retail stores... ie.. Garts.. Dicks.. Scheels.. etc.. they may even be able to patch it up for you .. hope this helps..I know when I need a replacement if I bring the whole bike in they will even put the new tube on the tire for free,,,
Jan 20, 2010 | Zooper Zydeco Z344 Jogger
Broken front wheels on zooper double stroller
Oct 31, 2008 | Zooper Tango double stroller - Red
Stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Jan 10, 2008 | Zooper Cool Zone Buddy Stroller
Making my zooper available to 2 children with an attachment
First of all, a heartfelt congratulations! Second, it's definitely challenging having children so close together.
The Zooper Boogie is a good stroller and it's engineered in a VERY specific way to provide baby safety and comfort. It does this by providing a slightly lower center of gravity focused on the rotating single front wheel. This makes it more maneuverable for parents and keeps baby at the center of the swivel. Attaching a second compartment on the front or back of this particular carriage would undermine the engineered balance, tremendously. At least one occupant would suffer from an extended swing when maneuvering that could be more than just uncomfortable, especially if it was extended forward over the front wheel. Some stroller companies might be willing to do this, Zooper doesn't.
The best alternative that they offer is the Tango which is engineered for two. I know that you mentioned that you wouldn't purchase a double stroller but modifying a single might be uncomfortable and possibly dangerous for your little ones. I would recommend against it.
Once again, congratulations on your blessings!
Nov 11, 2007 | Zooper Boogie Jogger
Problems with releasing front wheel lock
I have just fixed my stroller which had a similar problem. The wheel was still swivelling but it was sticking slightly. I noticed that the pin that locks the wheel in place was half out and therefore the wheel was getting caught on it. I undid the nut that holds the end of the wheel lock cable in place and tightened this as tight as I could which pulls the pin back into place (making sure that the switch is in swivel position). I then put the washer and nut back on (making sure cable was as tight as possible).
May 30, 2007 | Zooper Boogie Jogger Stroller
Zooper Zydeco
Our stroller had a similar break, just below the 'pivot point'. I have been in touch with Zooper directly (Dan Slaughter - dans@zooper.com) and had a new piece shipped to us in Toronto for about $20 American. Removing the old piece wasn't too bad, but I did have to drill out the old rivots. I am however having problems reinstalling the new piece, because of the wires contained within the steel frame (which allow the folding function). If you can do without the folding function, you're laughing. That's what I'm considering doing. Hope this helps. Jason.
Jan 31, 2007 | Zooper Zydeco Z344 Jogger
Steering problem - Zooper Boogie
I had the same problem and took it back to where i bought it. THey sent it in and had the whole front wheel and corresponding parts replaced. A few weeks later the same probem occured. I just sold the stroller as is. You could try to contact Zooper directly, but don't get your hopes up, sorry.
Jan 20, 2007 | Zooper Boogie - Red Jogger Stroller
Zooper Zydeco Z344 Jogger Logo
179 people viewed this question
Top Zooper Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
Dorel UK
Dorel UK
Are you a Zooper Baby Gear Expert? Answer questions, earn points and help others
