Question about Car Audio & Video
Tail lights 2001 Saturn Ls L100 No tail lights when lights are turned on.
  • 631 Answers
For some reason, this was posted to the car audio amplifier troubleshooting section. Repost the question in a more applicable section and someone should be able to help you.
While waiting, check all fuses related to lighting. There may be more than one fuse box so check them all.
Posted on Sep 07, 2008
Cannot get the key in ingition, do not know how to turn off the passlock
Passlock is tricky. There is no way to just turn it off. It is an antitheft system, if you could turn it off, so could a potential theif. I do know of a way to bypass it tho. Check out this link. Alot of info, and some DO IT YOURSELF solutions
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Saturn
2000 LS/LS1/LS2/LW1/LW2
2001-2002 L100/LW100
2001-2003 L200/LW200
2001-2005 L300/LW300
2004-2005 L-Series
2002-2008 VUE
1996-2002 SL/SL1/SL2
1996-2002 SC1/SC2
1996-2002 SW1/SW2
May 22, 2011 | 2007 Saturn VUE FWD 4
My wires on the antitheft connector on my 2000 saturn sw2 were cut and now it wont start
Ya, cutting those wires will definately cause the NO START. Depending on what was done, you might be able to fix it, might not. If not, there are ways to bypass the entire system. Here is some good info on the situation, and some possible solutions.
Full bypass works on these car.
Saturn
2004-2005 L-Series
2002-2008 VUE
1996-2002 SC1/SC2
1996-2002 SW1/SW2
May 15, 2011 | Saturn SW2 Cars & Trucks
I just want to ask , my friend have a problem with he's saturn s-series 2001, the problem is it is really hard to start we just only hear a click noise so we decide to change the starter, but i just...
Alot of the time the anti theft security can actually disable your starter. Check to see if there is a light on the dash that says SECURITY or a little picture of a car with a lock thru it. This would be a dead give away of the security problem. Check out this link for info and DO IT YOURSELF solutions to this problem.
Saturn
2004-2005 L-Series
2002-2008 VUE
1996-2002 SC1/SC2
1996-2002 SW1/SW2
May 15, 2011 | 2001 Saturn S-Series
2000 saturn ls. brake lights work but tail lights will not turn on
Saturn tail light housings are a known problem. Saturn had a service bulletin on them and would even compensate for the expense of the replacement for the 2000 model in late 2000 and 2001. The contacts are cheesey and made of plastic...get hot then warp and break. Poor design and a unreliable system. Cost on replacements is very high. You might find a useable one in a salvage yard, hard to say if it works until you install it.
Apr 27, 2011 | 2000 Saturn Ls 4dr Sedan
How do you reset a service engine light on 2001 saturn l100?
You will need a OBD II scanner to reset or turn off the MIL (Malfunction Indicator Lamp).
Jun 17, 2010 | 2001 Saturn L-Series
2001 saturn L100 brake lights stay on when lights are turned on
check for incorrect brake light bulbs or tail lights. Some look the same but are different.
Apr 04, 2009 | 1999 Saturn SL
Wiper motor replacement 2001 saturn l100
Steve, You can find information at several web sites. One is All Data but they will charge you for each individual vehicle but Auto Zone will provide most vehicles for free.
Good luck.
Regards,
Jan 21, 2009 | 2001 Saturn L-Series
Tail lights and brake lights not working with headlights on
We had the same problem with ours, that is a Saturn recall items. Check with your Saturn dealer to see if it is still in effect. It use to make our headlight switch get hot. I think it was a poor ground in the taillight housing, I use to wiggle the bulb plug-ins and that helped for a while, but after the recall was fixed it never did it again.
Dec 07, 2008 | 2000 Saturn Ls 4dr Sedan
Brake Lights
The brake lights are engaged by a switch when you press the brake pedal. It is a plunger type switch, then when released, turns on the lights.
It appears that the plunger is not extending and making the connection. Try press on the brake pedal with one hand, and plull out on the switch plunger, see if the lights come on.
You should be able to replace the switch for less than $10
Jun 08, 2008 | 2004 Saturn ION
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
