Question about Whirlpool Dryers
Whirlpool gas dryer
Dryer not heating properly, took off back panel and start dyrer, heat up for about 10 sec. then heat shuts off for about 3 min, then heats back up etc, ???
  • 706 Answers
From the sound of your problem, it appears you may have a faulty overtemp switch that gets too hot , opens the circuit to disable gas and flame, then cools down and allows it to start again.. Since you didn't provide a specific model number with your question.. use this link to find replacement whirlpool thermal fuses etc.. http://www.pcappliancerepair.com/whirlpool-dryer.php#fuse
Hope this helps..
Posted on Sep 07, 2008
The dryer keeps stopping (the timer skips from 50 mins to 10 mins in secs) AND what worries me the most is, I haven't needed to empty the lint trap.
Well, well.
Am I to understand the timer dial is going really fast as you watch it?
I didn't know that was possible, but maybe the wiring has been compromised (shorted out) somehow. If so, you would need to take it all back apart and look for a wire that is pinched or incorrectly hooked up. Some Whirlpool dryers have numbers on the back of the timer that are supposed to match numbers that are actually printed on the wires themselves.
As far as the lint trap, perhaps one of the "pipes" inside the dryer is unhooked or loose causing the hot air to miss the screen.
Be blessed.
Aug 27, 2012 | Whirlpool 8579123A DUET DRYER DR REVERSAL...
some were he has blocked the out let for lint trap the reason its stopping is its over heating don't use untill sorted it will cause a fire if left
My whirlpool gas dryer stopped getting hot in the middle of a cycle. We took the back panel off and cleaned it to make sure there was no excess lint. Is it worth getting fixed? Joyce
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 20, 2011 | Whirlpool Dryers
Whirlpool gas dryer blows cold air. took back panel off cleaned lint out. Took front cover off, turned dryer on gas igniter does not heat up, or glow model # lgr4634jq0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 09, 2010 | Dryers
I have a gas dryer that doesn't heat. The falme comes on last for about 10 secs then cuts off. I have replaced both coils and high limit thermostat.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 11, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer runs then stops after short periods (5-10 mins)
THere maybe a thermal limit sensor gone bad. Keeps the dryer from over-heating. Located behind rear panel on most and mounted on the heat tube. Verify with volt/ohm meter if possible
Jul 28, 2009 | Kenmore 73952 Gas Dryer
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Thanks
Vic
Jun 01, 2009 | Dryers
Whirlpool Dryer LGQ9508PW0 flame comes on and shuts off after 30 seconds.
this might actually be normal, whats the complaint??? to long to dry clothes maybe 2-3 cycles??? would be a common complaint. in which id check to make sure vent is not clogged anywhere, especially where exiting the home if he venting is ok id replace the coils atop the gas valve, possible and common for that matter that after running for 20-30 min they do not reopen and dont allow flem to reignite... part number 279834 retails for about $20 easy enough repair.... reason for flame to go on and turn off after only 30 secs is that in an empty dryer 30 secs of heat may be enough to satisfy the thermostat, that's alot of heat for an empty dryer, it would remain on for longer with a load of wet clothes absorbing the heat
Nov 05, 2008 | Whirlpool LGQ9858P Gas Dryer
Gas dryer tumbles no heat.
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
May 02, 2008 | Dryers
Dryers Logo
132 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
