Question about GE WHRE5260E Top Load Washer
Washing machine won''t drain
Washing macine won't drain
  • Anonymous Mar 30, 2014
    WTW4800XQ4
  • 943 Answers
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Posted on Sep 11, 2008
I need a fill hose for a washer macines lg
drain out pump is in the open position ,due to some object is struck at the mouth .remove drain out pump and re fix.
May 18, 2014 | LG WFT1071TP Top Load Washer
Soap water flows through the outlet pipe while soaking
are you referring to the drain pipe from the washer ? if so your drain pipe is mounted to low , it should be mounted so the elbow is above the level for a full load in your washing macine
Jan 10, 2012 | Whirlpool Washing Machines
I have replaced the agitator dogs on my washing machine. Machine will fill and drain but will not spin, the macine even after replacing the dogs barley agitates. What could the problem be? Kenmore 70...
the motor coupling is the most likely problem
this video will show you how to replace the couplinghttp://www.youtube.com/embed/9K1KHEogf3c" frameborder="0" allowfullscreen>
Jul 19, 2011 | Kenmore Washing Machines
The front loader door won't open after the cycle what can I do
1. If it is an old machine with a mechanicvcal selector, make sure the selector is set to the end of a program.
2. Unplug the macine from the mains and leave 20 minutes. That will ensure it has reset. You should be able to open the door.
Jul 01, 2011 | LG Washing Machines
Leak in washing macine
The most likely place on these to find a leak is the pump
This training MANUAL will hep
May 28, 2010 | Whirlpool LSR7333 Top Load Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Won't spin or drain. Only a hum. Rocky
Ur internal engine if busted u have strap to change for the spinn and chek the outside of ur macine neer her drain to se were is the plug. if not and ur machanie is in the basement see bout the house drain
Nov 19, 2009 | Roper RAS6233KQ Top Load Washer
LG fuzzy Logic 5.5 WF T552
check drain to see if plugged. if it can't spin water out, it will shut down.
Oct 21, 2008 | LG Washing Machines
Fills and drains straight away
The only thing i can think of is your drain hose is lower then the actual drain hookup. Raise the hose higher than the top of the macine .
EEggman
Mar 07, 2008 | Dyson Flowcheck CRO1 Front Load Washer
GE WHRE5260E Top Load Washer Logo
231 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
