Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Internet connection-Linksys Wireless B
I moved my computer set-up for a few days. When I set it up again I lost the wireless internet connection to the broadband router on my main computer. Can disconnecting it cause a problem? How do I troubleshoot this issue?
Thanks, Bill
  • 2,071 Answers
Try to reset computer by unplugging for 1 hours and put it back after 1hour. If the reset did not work try using an usb powered hub in the middle, this sometimes fix the problem.
If the HDD still does not work after the above then it is probably faulty.
Here you can buy an USB hub: Linksys ProConnect USB2HUB4 4 Port Wired USB Hub
Posted on Sep 06, 2008
    Scholar:
  • 141 Answers
Did you move the router out of range of the computer? It sounds like you put it back where it was but I just thought I'd ask.
Otherwise, use your wired connection to check the router settings. It is possible that the wireless settings defaulted due to the disconnection. You can either set the router to match your wireless computer if you can remember, or just set up a fresh wireless connection between the two.
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
Internet by wireless doesn't work
Call linksys @ 18668705819, they will give you free tech support, since the router is new.
Sep 24, 2009 | Linksys WAG200G Router
Problems with internet connection linksys wireless WRT54GS
hello i'd change it to belkin router good luck
shaun
Aug 24, 2009 | Computers & Internet
Cannot connect wirelessly
You need to setup cisco page, with your ISP. Your setup name and password must be same for all computers. All computers for this installation must connected by wire at the beginning. And make sure you enable the wireless options on Linksys page. READ HELP form Linksys main page.
Aug 12, 2009 | Linksys Wireless-G WRT54G Router
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Lost connection to internet after 2 days
I ran into the same problem when i was living in Reno.
I fixed my problem by First, Access Command Prompt, by way of Run Program: CMD
then i inputed the command ipconfig /all
Find the wireless portion in the information that it gives you, what you are looking for is the Mac Address. it should be 12 total Alpha Numeric string, which is seperated every 2 by a dash marker.
Next, access the router through the normal way of browser, In the Wireless section, there is a tab that you select to input the Mac Address into the router, to basically give the router a permission to always give that computer access to the internet. This worked for me. I do hope it works for you. Its what i have always done in the past when i set up wireless Offices
Oct 28, 2008 | Linksys Wireless-G WRT54G Router
How to set up the wireless-G 2.4 ghz 54mbps LINKSYS
I have moved and lost my CD to my Cisco "Linksys" wireless-G model WRT54GS please tell me how I can download the disk from somewhere???
Joyce
Jul 11, 2008 | Linksys Wireless-G Broadband Router
Lost internet on my desktop which uses wireless lan card and antenna to connect to linksys wireless g
Just a question, did your girlfriend accidentally kick your computer off the network by accident?
Mar 23, 2008 | Linksys Wireless-G Broadband Router
I can't get my new Vista computer to connect to my wireless network
I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since.
If that doesn't help, try removing the Linksys software from your computer and try the network adapter remove/reinstall again.
Jan 10, 2008 | Linksys Wireless-G Broadband Router
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
