Question about Ruud Heating & Cooling
Coils in my new aircondition system are corroding and test tell me that it is sulfur dioxide this a new home with out anyone living in it....could it be bad copper????there is a crematory real close????
  • 1 more comment
  • gwbashant Sep 06, 2008
    coil in a new Rudd a/C system are corroding and test say it is sufur dioxide causing...this has happened in many of my new houses and some of the coils I have repaces several times..what is causing this...some are unoccupied homes and some are accupied
    coil in a new Rudd a/C system are corroding and test say it is sufure dioxide causing...this has happened in many of my new houses and some of the coils I have replaced several times..what is causing this...some are unoccupied homes and some are accupied
    Genius:
  • 1,269 Answers
The coil is very exposed to weather, air and moist. Better cover the coil a foil. Clean it first with metal cleaner then cover it.
Posted on Sep 06, 2008
  • 19,396 Answers
How old is the AC?: if the oxide is not too much just remove it with cleaner, if pipes are rottening, then you will need to replace lines.
    Scholar:
  • 141 Answers
I doubt that it is bad copper. It could be outgassing from the crematorium. you can get a coil cleaner spray, but that doesn't explain what caused it in the first place.
I have a Chrysler pt cruiser 2003 , when starting it's mis firing, it has no power when driving and it produces rotten egg smell
you have a clogged up catalytic converter there are some ways to unclog on youtube if you can get to it you can put a piece of wire in a drill and spin it inside to break up the carbon build up its hard to get out best to change good luck with it some people drill holes in it to relieve presure
Mar 19, 2015 | 2003 Chrysler PT Cruiser
What would be causing what sulfur smelling exhaust smoke?
The Smell is-- Sulfur Dioxide-- from an over heated
Exhaust Converter
Yes-- it will be ruined soon
White Smoke all the time, could be a head gasket
It could also be-- lots of fuel-- that is overheating the converter
Have to look at fuel trim on scan tool data
Aug 23, 2014 | 2012 Ford Fusion S Sedan 2.5L 4-cyl....
2SO2 + O2 -------> V2O5 2SO3 which of the chemical symbols is the catalyst?
(s) + O2(g) -----> SO2(g)
The gases are mixed with more air then cleaned by electrostatic precipitation to remove any particulate matter
The mixture of sulfur dioxide and air is heated to 450oC and subjected to a pressure of 101.3 - 202.6 kPa (1 -2 atmospheres) in the presence of a vanadium catalyst (vanadium (V) oxide) to produce sulfur trioxide, SO3(g), with a yield of 98%.
2SO2(g) + O2(g) -----> 2SO3(g)
Read more: http://www.articlesbase.com/gadgets-and-gizmos-articles/prooduce-of-sulfuric-acid-555947.html#ixzz1VC0BMWac
Aug 16, 2011 | Computers & Internet
Our Maytag washer emit a rotten egg smell and the wet clothes also come out with this smell. What is causing this and how do we fix this issue?
Sounds like a sulfur-eating bacteria, you're smelling hydrogen sulfide. Are you on city water or do you have a well? Sulfur-eating bacteria can live in a well (as can iron-eating bacteria) and it might find a happy home in a washing machine too.
Since they live in an acidic environment (the hydrogen sulfide, dissolved in water, makes an acid) I would try a caustic first- bleach would be a good first bet.
If you have a well and the bacteria came from it then it'll come back. Consult with a local well drilling operation, they can tell you if you have bacteria in your well and how to deal with it in a locally acceptable fashion.
lp
Dec 29, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Just rented a home in the country the water smells like rotten eggs
Hydrogen Sulfide Gas can occur in wells, and gives the water a characteristic "rotten egg" taste or odor.
  • Install an activated carbon filter. This option is only effective for low hydrogen sulfide levels, The gas is trapped by the carbon filter is saturated.
  • Install an oxidizing filter, such as a "manganese greensand" filter. Manganese greensand filters are often used to treat iron problems in water. The device consists of manganese greensand media, which is sand coated with manganese dioxide. The hydrogen sulfide gas in the water is changed to tiny particles of sulfur as it passes through the filter. The filter must be periodically regenerated, using potassium permanganate, before the capacity of the greensand is exhausted.
  • Install an oxidation-filtration system. These systems utilize a chemical feed pump to inject an oxidizing chemical, such as chlorine, into the water supply line prior to a storage or mixing tank. When sufficient contact time is allowed, the oxidizing chemical changes the hydrogen sulfide to sulfur, which is then removed by a particulate filter, such as a manganese greensand filter.
  • Aug 08, 2010 | Whirlpool Water Heaters
    What is the name of the process called when you extract copper from a liquid
    It is broadly classified or called as solvent extraction but if you say liquid, the actual extraction name differs like sulfur dioxide or later form can be sulfur acid etc.
    Jun 26, 2010 | Cosmi Homeworkhelp.Com Super Tutor HS...
    2003 buick rendezous windows frost up, motor seem to heat up ok 195+, all ready install new stat. getting hard to see here in Minn
    Actually the defrosters rely on the airconditioning evaporator coil to remove moisture by freezing it on the coil, kind of a dehumidifying effect. The heater will still put out warm air while it does this. If your airconditioning system doesnt work, chances are the defroster wont be very effective.
    Jan 09, 2010 | Buick Rendezvous Cars & Trucks
    I have a 2002 Chevy Tracker with a sulfur smell. It passed the e test and has no engine codes. It is worse climbing hills but has no power loss.
    Hydrogen sulfide in the exhaust, which is produced by trace amounts of sulfur in gasoline. It's supposed to be converted to sulfur dioxide in your catalytic converter.
    This may be indicative of a fuel-injection problem, and can be cured by a sharp mechanic.
    But often it means a failed catalytic converter.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 18, 2009 | 2002 Rolls Royce Rolls Royce Silver Spur
    Refridgerator
    YES THIS ISSUE THAT YOU HAVE MOST PEOPLE DO NOT BELIEVE EXISTS BUT IT DOES AS YOU KNOW
    The solve for the solution is to spray paint all of the copper tubing at the compressor connections , and any of the tubing that you can even if it means laying the machine down on its back to get to them black enemel spray paint will work you choose gloss or satin. it keeps the sulfur gas from attacking the copper
    btw take a look at other items in the house that have copper in them light fixtures light swithes recepticals, air conditioning coils
    bet that they are tarnished
    Apr 17, 2008 | Refrigerators
    Heating & Cooling Logo
    Top Ruud Heating & Cooling Experts
    Donni Steen
    Bill Long
    Tim Whalen
    Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
