The blade head keeps slipping down disengaging the internal rotating rod from it's first junction just above the bend, so it won't spin. How do you fix?
My previous comment is not correct. I believe you can add more grip to the extension by adding a washer under the clamp. I have not tried this, but it is worth a try. Be sure to examine the joint and make sure that it is seating properly. The attachment must be seated all the way, to insure that the shaft is engaged in the housing receptacle.
You can't post conmments that contain an email address.
Usually, the upper blade flips up and out of the way. Sometimes pushing in on the blade and rotating upwards will work, otherwise the manual should have instructions. HOWEVER, that typically does not "disengage" the blades. It just removes the top blade from contacting the lower blade. It is recommended to not sew without the blades engaged. Doing so allows the fabric to contact the loopers and can bend, break, or knock them out of time.
Typically, wiper arms terminate in a "J" shape at the end of the arm where it connects to the wiper blade.
Purchase new wiper blades the proper length.
Hinge the wiper arm up away from the windshield so it's sticking straight up from the car.
Rotate the wiper blade so that it's perpendicular with the arm.
Now press the wiper blade assembly so that it disengages from the hooked "J" bend in the arm.
Re-attach the new blades using the same procedure but in reverse.
Another possibility is that the two prongs that couple the motor in the base with the rotor in the baking pan can slightly bend when kneading heavy breads. This slant can create a force that pushes the pan upward while kneading. This is the same principle as rotating a vertically mounted screw causes it moving up or down. A simple solution is to use pliers to slightly bend the prongs in the direction of rotation to make them exactly perpendicular to the rotation plane. The prongs should be visible when the baking pan is removed. There is a well in the center of the base and inside that well there is an S shaped blade mounted on the spindle of the motor, which the ends of the S bent at 90 degrees upward. Those two ends push the two arms of the rotor in the baking pan. You should first determine the direction of the rotation by starting the machine (it is clockwise in my machine), and then grab each upward end of the S-blade with pliers and bend it slightly in the SAME direction as the assembly rotates.
Kindly check the rotor carefuly.. there is one white/black color rotor fixed on the bar of Motor rotates whith motor and there is anoter rotator which attached parally with its i.e once motor rotator moves the another ones also moves (which connected with the rod of Blades) some times these rotators gets loose by time and makes the rotation of Blades weak. kindly connect the same tightly and check....
Does the rack raise? Are you hearing a buzzing every second? You could have a bad rotation motor, or the drive chain could have just fallen off. Both of these repairs aren't terribly difficult but are extremely annoying. It might be a best use of your time and resources to call an authorized service provider and have them repair the issue. If you're feeling ambitious the first thing you want to do is verify that your rotation motor is still functioning and that the gearbox is not stripped out. Make sure the supply power to the oven is off, climb up on top of the oven and remove the covers over the lift and rotation assembly if they are not already removed. You should see a black cylindrical motor with a plastic fan blade on the top, this is your rotation motor. Spin the fan blade with your finger while looking at the motor shaft, it should be rotating, if it is not you need a new motor. To change your rotation motor you will need a 5/16" ratcheting box wrench and it can be a nightmare the first time you change one. Unwire the motor, pay attention to which wires you disconnected. Remove the four screws underneath the motor and slide the motor straight up through the hole. Change the chain sprocket over to your new motor and reverse the steps.
If your motor IS rotating when you spin the fan then your chain may have slipped off. Loosen the four screws holding the rotation motor in place so you can slide it back and forth. Lift up on the shaft and place a screw driver in between the metal disc above the big sprocket to keep the weight off of the sprocket. Put the chain on the small sprocket first and then slowly work the chain onto the large sprocket. Once the chain is on lower the shaft back down and tighten the motor back up. Hopefully your rack should start rotating again, if it doesn't the gears in the gearbox could still be stripped causing it to slip, in which case you should call an authorized service provider to service the oven, or see above.
the cam plate that the tensioner pulley is mounted on that rotates back around to tighten the belt as the cable or rod is engaged is likely rusted and worn, there is a bushing in this pivot that can be removed and cleaned fairly easily with a abrasive wheel or pad and lubricated upon reassembly.
Yes worn belts do stretch. On an MTD mower, like yours, there are blade brakes assemblies on either side of the mower where your feet rest. They stop the blade rotation when they make contact with the top of the deck pulley assembly. Part # 761-0168B Is the part # , you are looking for, you will need two of them. Good Day.
The motor is 'locked up' that's where the heat is coming from. It may have a bad bushing or something is jammed. Give it a good look over you may see it. Does the blade feel hard to turn?
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
