Question about Brother XL-6562 Mechanical Sewing Machine
The reverse sewing lever (page 24 of the manual) is loose and does not work. I feel that the plastic lever has broken and I would like to replace it. I tried to take the plastic cover off of the XL-6562 machine to get a better look at the problem but could not take the cover off without forcing it (and possibly breaking the plastic cover). Also, the connecting plug on the XL-6562 is loose and I have to be careful when plugging the machine in to the power cord of the machine. When lifting the machine and turning it, I hear loose noises like a borken piece of plastic or a loose metal screw falling around inside the machine. I think that if I could get the plastic cover off of the machine, I would be able to see what the problems are with the machine. I have taken all of the metal screws off of the plastic casing, but still the plastic cover will not come off. Can you help me figure out how to get the plastic cover off of the machine? Thanks, MB
Dear jbanistr,
My wife and I just had this same problem (or at least getting the cover off) and have a possible solution. Safety first, unplug your machine from the wall. Next remove all the screws, three by handle, three on the bottom, one on the rear of the sleeve arm, one on the light bulb cover and one inside the lightbulb cover that goes sideways into the frame. I believe that's all of them but look for any that hold plastic-to-plastic or plastic-to-metal. Take note not to change the stich settings or else you'll have to find and set the number wheel and the adjuster to match, not fun. The way we did it was starting from the top, pry the case apart slightly and with a flat screwdriver gently lift the case over the three adjusting wheels so they clear. We then, with difficulty, pried the case the rest of the way open, with a really loud pop! A better way might have been to start pring from the bottom, but it worked. Reassembly was just the reverse, just fit the top first and put all those screws back in.
Hope this helps.
Posted on Oct 20, 2008
Brother xl-6562
Check the clamp for a crack it sounds like it may have been broken. Good luck
Jul 21, 2012 | Brother XL-6562 Mechanical Sewing Machine
Machine stuck in reverse will not go forward
With these very cheaply made Brother models, unfortunately it is going to need to go for repair, if you try to open the casing you WILL break something.
Oct 23, 2011 | Brother XL-6562 Mechanical Sewing Machine
The entire mechanisim that holds the needle to the shaft ...this part won't stay on the shaft. Help
Get a copy of the sewing machine manual at brother.com. Sounds like you need to tighten the screws, use a coin or screw driver
Aug 30, 2010 | Brother XL-6562 Mechanical Sewing Machine
My sewing machine bobbing is bunching/gathering when I sew.
Hi. It's probably because your upper tension is too loose. Read my tips on setting your tension and see if that helps.
Jul 20, 2010 | Brother XL-6562 Mechanical Sewing Machine
I need spare part for Brother XL -6562. I don't need expert I can
Have you tried contacting a Brother sewing machine dealer to see if they will order the part?
Feb 18, 2010 | Brother XL-6562 Mechanical Sewing Machine
How do you monogram and embroider with this sewing machine (brother XL-6562
Turn the pattern selector to the pattern you want, set the width and length dials to your liking.
Your machine does not do embroidery.
Feb 09, 2010 | Brother XL-6562 Mechanical Sewing Machine
Looking for a sewing machine similar to the Brother XL 6562...
I have an XR-65 (discontinued also for a XRT65) and I adore it. I'd recommend it!
Apr 16, 2009 | Brother XL-6562 Mechanical Sewing Machine
Brother XL-6562 Mechanical Sewing Machine Logo
202 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
