Question about SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television
TV Will Not come on
Where do I get this power supply board?
  • RV EXTERIOR COATINGS May 11, 2010
    Do you still have the SVA you posted the power board problem about?
    If so did you get it fixed?? If not do you want to sale it. I need parts to fix mine. A surge took out several other comp[onents.
    MrJohnMikel@Gmail.com
I bought the power board, HD4208TIII-PD from www.shopsva.com this past March. It arrived and works fine.
Posted on Sep 28, 2008
I have a panasonic TC-P42C1 blinks 10 times no picture no sound What is common to go on this model (which board)?
Check the tv power supply board.That the board where the tv power A/c plug into it.Check the tv power supply board carefully for dying components parts that are called capacitors parts.Bad or dying capacitors parts on the tv power supply board are alway causes this problems to the tv.Bad or dying capacitors parts are very easily to spots,all these capacitors parts are alway bulges up onto it tops.Never have plats round tops as they suppose too.U have all the tools and know basic electronic also can do basic soldering work,u should changes all these dying capacitors parts in the tv power supply board with no problems at all.If u check all over the tv power supply board and it have no dying and leaking capacitors parts to the tv power supply board all.Then the tv Y-Sustain main logic Tuner board it is the causes and the problems.The tv Y-Sustain main logic Tuner signal board that is the board that take in the tv imcomming tv broadcasting signal cable plug into it.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board and or the tv Y-Sustain main logic Tuner signal board for the replacement.
Nov 06, 2011 | Panasonic TCP42C1 Plasma TV
60 inch LG Plasma, did have to push the power button 5 to 7 times to get the TV to power up. Now it will not come on at all
The tv before,the tv power supply board already have problems and was slowly dying,that why it require u to pushes 5 to 7 times for the tv power supply board to be able to sustance and hold power for the tv.Now the tv power supply board it is alot weaker or already dead.That why the tv dose not power on anymore.The tv power supply board that the board where the tv power a/c cord plug into it.Try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 06, 2011 | LG 60PC1D 60 in. Plasma Television
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
I have a 32lc7d tv and i cant get it to turn on all the time. the on light will be green but no sound or picture. the light also blinks about 15 times before going to a solid green color. the tv will...
This problems ur tv are having are only can be causes by two boards,the tv power supply board or the tv Tuner signal board.The tv power supply board that the board where the power a/c cord plug into it.The tv Tuner signal board that the board where the incomming broadcasting signal wire plug into it.This problems very easy to fix.If it is the tv power supply board is the causes,because u can check the tv power supply board carefully u will find dying capacitors parts that will bulging up or puffing up on to it tops.U have all the tools and know basic electronic just replaced all the dying capactors for all new capcitors parts same micro ferit but the capacitors voltages like 5 or 10 voltages higher for better heat resistance for the life of the tv power supply board.If it is the tv Tuner signal board,very hard fix and determine where the dying parts are in this board,because this board is cover with many ICS chips on this board.If the tv the Tuner signal board is the problems best just buy the whole refurbish tv Tuner signal board for the replacement.Or u can tries websites like Shopjimmy.com,Ebay.com to buy the whole refurbish tv power supply board too,if u don't know how to or have all the tools to replaced those dying capacitors parts and also can buy the whole refurbish tv Tuner signal in these two websites too.
Apr 16, 2011 | LG 32LC7D Television
Standby light sometimes comes on. When on and control box pressed turns green then switches back to red with clicking noises coming from set. Seems to be going through various sources.
This tv problems u have are only can be causes by only two boards 90% lightly it is the tv power supply board.5% it could be the tv Tuner signal board.5% could be both boards are dead require changes both boards.The tv power supply board it is the board that where the tv power a/c cord plug into it.The tv Tuner signal board it is the board that where the incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a whole refurbishes power supply board or tv Tuner signal board or both.
Apr 06, 2011 | Hitachi L32H01 32 in. HD-Ready LCD TV
I lost power in my house. I cannot get the TV to power up. Is there a reset button? what do I have to do to get power on the TV? All the other components linked to the TV are working.
Now,there is no power to the tv at all?Yes.Tries tv unplug,replug it back like about and hour later.That the resetting tv back to the factory setting.The tv now should be working again.If tv still have the same result,tv power supply board have problems,that the board,where the power a/c cord plug into it.Check the tv power supply board fuse,because u lost main power to the house.If u lucky,the tv power supply board only have a dead fuse,fuse is near where the power a/c plug,plug into tv to get it power.Fuse can buy it anywhere like Radio Shack like $1.50.After u repalced the fuse,if tv still getting the same result,than sorry ur whole power supply board have problems and it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Feb 23, 2011 | Samsung LN52A850 52 in. LCD HDTV
The TV shuts off then the power/standby light blinks continuous for about 20-30 times then TV turns back on.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop, but if otherwise Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 16, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
My lg tv is flashing at the bottom and will not turn on
Unplug,replug the tv to reset it self?Not.Take the tv aparts.Power supply board have dead parts,call capacitors,check power supply board,that the board have a a/c power cord plug into it.That the power supply board.Know basic electronic's?Know how to do soldering,have tools like soldering iron and solders?Check power supply board for those dying capacitors parts,alway bulges up on it tops or puff up on it tops.These capacitors must be replaced in the power supply board.Now the tv shuold have stable ur power light and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jul 04, 2010 | LG RU-52SZ61D 52" TV
No Power
Take ur tv aparts.Ur tv power supply board,that the board where the power a/c cord plug into it.That is ur power supply board.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Tv little green light is blinking but tv won't power on
Ur tv power supply board it dead.The power supply board,that the board the a/c power coard go into it,that ur tv power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replament.
May 26, 2010 | Dell W3000 30 in. HD-Ready LCD Television
SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready Plasma Television Logo
74 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
