Dynex TV I just got a dynex 37" lcd tv but can't figure our which screws to remove to get the base off. I removed 5 screws from the bottom (on I had it mounted on the wall), but the base is now just loose, but I can't get it off. Please help! Josh
You have a bad LCD control board going bad,Color getting floresent? Or pixely? esp. when you have it on for a bit. Common prop. But finding parts is a prob.
They are no longer in buis. Try Shop Jimmy,or even Ebay. Encompass does not have any. Runs about 40-60.
Remove 4 screws holding the vertical metal bracket in place. These are located just above the bottom of the rear centre of the TV. The bracket will then slide out.
You might find it easier to remove the footplate first. Simply remove all screws from the bottom of the base. The metal plate and the plastic shield will then detach.
Exactly the same problem
