Question about Sony PlayStation Portable (PSP) Console
Cannot read disc
Everything on the system works except it wont read discs. i cleaned the lense but nothing. please help
    Problem Solver:
  • 13 Answers
Your laser probably broke.
You should replace the laser module. You can order one at online shops like http://www.consoleparts4u.co.uk/ or buy a cheap laser part on eBay, but watch out with buying components that are made in China/Hong Kong. There is a bigger chance of bad quality.
There is no soldering involved into replacing a PSP laser part. But you should watch out with static electricity and i recommend you following up a disassembly tutorial, for example the one here: http://www.consolezombie.com/PSP/PSP_Laser_Replacement.html
Posted on Oct 08, 2008
Hi, My S-Master 5.1 Digital Amplifier can't read any DVD and every time it give a no disc error, i tried many DVDs with no good except one time it worked fine and after that the same No Disc error every...
Most disc read errors are caused by dust or dirt on the lens of the DVD player. You should follow the cleaning instructions. Or watch a YouTube video on cleaning DVD lenses.
Oct 12, 2013 | Sony TA-N9000ES 5-Channel Amplifier
My disc drive wont read discs at all, my cousin knows alot about computers and said its the laser it seems like. how do I fix this or replace it?
hi,
insert a disc cleanser first then play it several times,maybe the laser contained a dusts. mostly original disc driver are choosy,they can not read pirated disc..if your disc driver still not working, your laser might be defected.pull out your laser then change a new one..i hope this may help you,
best regards,
kaybicks
Feb 27, 2010 | Dell Inspiron 1525 Laptop
My denon adv 500sd wont read the discs can anyone help
If your unit has some time on it it probably has a dirty lense on the laser assembly. This isn't difficult to clean but you must exercise care not to damage any components of the laser assembly. Unplug the unit. Remove the top cover. If the disc drive has a cover, remove it. You should see the lense, looks like a fish eye, looking up at you. The lense is monted on a set of springs and will move around as you clean it. This is normal but do not apply anymore pressure than necessary. The alcohol will do the work loosening the dirt. Using 200 proof grain alcohol, available from any electronic parts supplier (www.mcmelectronic.com) and commercial grade, lint free, cotton swabs, also available at MCM, moisten swab and gently touch the lense rotating the swab head. Use a dry swab after the wet one. Blow dry the assembly with canned air, also available at MCM. Reassemble unit and you should have a working player. If you still are not reading discs you could have a defective or weak laser assembly. This would have to be replaced with a new unit. I hope this has helped you. Let me know if you need any more assistance.
hardrocko
Thank you for using FixYa
Feb 13, 2010 | Denon DHT500SD System
When my son starts to load a game it tells him to clean the disk or restart the console but it doesnt help
try getting optical lense disc cleaner kit from walmart,best buy ETC. it should clean your lense if your lense is dirty it will not read the discs .
Dec 15, 2009 | Microsoft Xbox 360 Console
Won't read a disk keeps saying reading then open tray
YOU NEED TO REPLACE THE LASER THAT READS THE DISCS IN THE DRIVE COSTS ABOUT £40,
HAD THIS PROBLEM MYSELF!
please rate me :)
Jul 27, 2009 | Microsoft Xbox 360 Console
Xbox Mech assault 2 lone wolf Limited Edition wont start
have you tryed actualy cleaning the xbox lense by running a lense cleaner ? your supposed to clean any lense that reads discs after every 10 hours of play time because of the dust thats getting collected .
Jul 22, 2009 | Microsoft MechAssault 2: Lone Wolf
Wont burn disc anymore
check to see if you can playback dvd movies or any other dvd if not then the dvd lense has gone on the dvd drive in which case you will need to purchase a new one , if you can at least playback dvds then it may be that the laser lense in the drive needs a clean and you can get a disc cleaner to clean the lense ( they have very soft brushes underneath the disc so whilst the disc is spinning around it cleans the lense )
This may help - if not then it will be a case of getting a new dvd rw drive and seeing as blu ray is out it will be cheap enough to replace.
I would suggest getting any computer hardware from http://www.newegg.com
Apr 17, 2009 | Televison & Video
Wont read audio discs
If you used a cleaning disc, try again only this time open up the unit and clean the lens using a cotton swab and alcohol. Those cleaning discs rarely work. Let me know if yuo still have a problem.
Dan
May 01, 2008 | JVC MX-K30 CD Shelf System
PS3 wont read any disc! any help appreciated !
im very sorry to hear this it has happend to me aswell. actualy im on my third ps3 all had the same malfunction. its nothing you can treat from the out side you can try to reformat and restore system defaults but it had no effect on any of mine. you may be able to fix it your self. try this link i realy hope you can fix it.i have read many post on this same thing your not alone im on number 3 because of this awful malfuction it could be very simple to fix like a dirty lense or the lense slider is stuck. i dont recommend useing a cleaning disk they dont make any for blue ray lense.the lense is very sensetive good luck dont lose hope.http://www.eurogamer.net/forum_thread_posts.php?forum_id=1&thread_id=73887&start=60
Apr 14, 2008 | Sony Playstation 3 (PS3) Console
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
