Question about Digital Lifestyle FA1B32Z 32 in. LCD Television
Vga audio in
What can u plug in the vga audio outlet in back of tv i tried my computer speakers to get better sound from internet but i got nothing have computer hooked up to tv thats why i m asking just looking for sound dont like the sound when speakers are hooked up directly to computer tower help someone
  • onejiz8 May 27, 2009
    thank u so very much for your time in ur help to me
    found one on ebay good price thanks for ur time in your reply to me ur the best man
    Scholar:
  • 141 Answers
VGA does not provide sound, only video signal.
to get sound, you need to run a signal from the audio output of the computer (1/8" mini) to the audio in of the TV (RCA).
Posted on Sep 06, 2008
On my Digital Lifestyles TV model LT4232, there is an (1/8" mini) input next to the VGA input. I picked up a $10 cable from a local shop and haven't had problems with it. If you are using an RCA on my tv the audio will be on a separate source from the video.
[URL=http://img509.imageshack.us/my.php?image=n12242001call10aril5.jpg][IMG]http://img509.imageshack.us/img509/8553/n12242001call10aril5.th.jpg[/IMG][/URL][URL=http://g.imageshack.us/thpix.php][IMG]http://img509.imageshack.us/images/thpix.gif[/IMG][/URL]
Posted on Oct 23, 2008
Tv hooked up to computer. connected audio cabe to vga audio in. still no sound. help.
I'll need a bit more information on your issue to help you first:
1.) You said: "trying to get sound on the tv to the computer". -- Did you perhaps mean that you're trying to get the audio which comes out of your computer to "play" on your TV?
2.) If I assume correctly, then you have the audio cable connected to the wrong place on the computer.. and possibly on the wrong place on the TV. If you are indeed trying to get the audio from your computer to play through the speakers on your TV, then you need to:
(this is also assuming you're using a "headphone jack-sized" plug on one end, with the other end being the old-style "RCA" left and right channels.. [Left = white; Red = right])
Firstly, the 'headphone jack"-style end of the audio cable needs to be plugged into the "audio out" or "headphones" jack. Sometimes the audio jacks on a computer are color-coded. If this is the case, the green jack is the one you want.
Next, the other end (which again I'm assuming are the left / right channels -- [white / red plugs]) needs to be plugged into the "audio in" on the TV which matches with the same input as your VGA cable is plugged into. Once the cable is hooked up in this way, you should be able to hear all audio coming from your computer on your TV's speakers.
Please let me know if I'm assuming incorrectly on what you're trying to accomplish with the audio. -- I hope I was helpful! Please let me know if you have any other questions!
Apr 01, 2014 | Proscan Televison & Video
I unplugged my sound system to re-arrange the living room and when I plugged it all back in it just wouldn't turn on at all. no lights, no nothing. I tried it in 3 different outlets and then in an...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 31, 2011 | Logitech X-540 Computer Speakers
I have a V-zon digital tv that I can't get the sound to work when I am on the internet or in other words I don't know how to hook the cable box to the tv to get the sound. The tv can only get the pictures...
When you are using the TV as a monitor (VGA) you need to connect the audio out from the computer to the VGA audio in of the TV. (Otherwise connect computer speakers to the computer (if a desktop) and use those speakers.) The audio out for a desktop is usually marked by a green 3.5 mm jack. The VGA audio in will be a 3.5 mm jack as well; so an audio patch cable (3.5 mm M/M) is needed. (The green port is normal for computer with Line-In, Line-Out and Microphone ports. If the computer has an option for surround sound, check the manual to make sure which port you should use for Line-Out.)
If your cable box has an internet connection (like some DVRs, blu-ray players and TVs), the HDMI cable will carry the audio without separating it out unless you feed the signal through a home theater system (or audio receiver) for a surround sound system.
Which model TV do you have? That will help track down where the VGA audio in port will be. Some models have the VGA audio in next to the VGA port. On other TVs, it is near other audio input and output jacks. Usually it is clearly labeled but you may need a magnifying glass to read the text. (Sometimes it will be labeled VGA/DVI audio in.)
I hope this helps.
(I have one TV in my household where the DVI audio in uses 2 RCA jacks, even with a computer as the source (so there may be some TVs with that for the VGA source as well). For that situation, I use a 3.5 mm to 2 RCA (M/M/M) cable or an adapter - either 2 RCA (F/F) to 3.5 mm (M) at the computer with an RCA audio cable or 2 RCA (M/M) to 3.5 mm (F) at the TV with a 3.5 mm audio patch cable.)
Apr 01, 2011 | Televison & Video
I have to connect my Presario CQ60 computer to my t.v. via a VGA port to view netflix movies. I have no S-video port on the computer. With the VGA I get netflix video but no audio through the t.v....
Hi, on the back of your t.v. near the V.G.A. input should be marked another small hole for P.C. AUDIO INPUT or something to that effect, it actually is nothing more than a headphone jack that you connect to P.C.'s LINE OUT/HEADPHONE jack-it's easy to find, the sound on your computer will stop when you plug in a " MALE TO MALE 1/8 INCH STEREO " cord into it. This will give you sound on your T.V. Good luck I hope this helps, Prodzilla.
Apr 01, 2011 | TruTech PVS2119 19 in. LCD Television
I turned on my xbox360, the speakers were working normally, i removed the VGA cable to confirm it was a VGA cable (want to buy an extension lead for it) then reconnected the cable, now neither of the...
also
hope this helps
Mar 17, 2011 | Logitech X-530 Computer Speakers
My speaker are not working. everything ishooked up, it says on my vloume control that there is sound but i hear nothing
also
hope this helps
Mar 15, 2011 | Cyber Acoustics CA-3090 Computer Speakers
How to install audio drivers in 845 vga audio driver not working
also
hope this helps
don
Mar 04, 2011 | Mercury P4VM800M7 Motherboard
Can not get this monitor to play sound on PC using XP Version 5.1. a driver needed?
there is not a windows xp 5.1 so I am going to take a wild guess and you mean you want 5.1 surround sound
If your computer plays sound through its own speakers normally then you do not need a driver.
I took this from the FAQ
  1. Make sure the audio cable is plugged in to the back of the monitor and in to the Green port in the back of the computer.
  2. Press the Right Arrow button on the monitor itself and set the volume to 10.
  3. Double check your audio settings on your computer and make sure nothing is muted.
This is not one of the better monitors in this price range having only a VGA input but is suitable for most people.
Aug 14, 2009 | Sylvania CL772B 17" Flat Panel LCD Monitor
I I get no sound from tv after hooking up computer
If you mean you've connected your computer to a VGA connector on the TV so you can use the TV as a monitor, not getting sound would be normal. The VGA input on the TV is video only. Any sounds the computer produces would still come only from the speakers you have connected to the computer. There isn't any problem that needs to be corrected.
If I'm not understanding your request, please post a follow-up comment and I'll try to help you further.
Mar 26, 2009 | Sharp LC37SH20U 37 in. LCD Television
I would like to know if I can use my Polk speakers on a Compaq 510 Evo c.p.u.
please check its compatibility in the user manual, if its going to work on your present OS or platform. then if its plug and play. And better check if the Audio input/output plug is compatible with your soundcard outlet at the back of your computer if so, please try to insert then have it tested if this will make sound...
Aug 04, 2008 | Polk Audio Computers & Internet
Digital Lifestyle FA1B32Z 32 in. LCD Television Logo
366 people viewed this question
Top Digital Lifestyle Televison & Video Experts
paul
paul
Are you a Digital Lifestyle Televison and Video Expert? Answer questions, earn points and help others
