Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
Nothing on the screen after power on
My HP Compaq fp 7317 monitor has problem and nothing on the screen after power on
  • 1 more comment
  • Anonymous Jan 05, 2008
    mine does not power on
  • Anonymous Feb 11, 2008
    screen just shuts off. have to remove power cable and re insert, then maybe it will stay on for a while. not sure what problem is
  • debranne Apr 08, 2008
    HP flat screen 1 1/2 old stop working. HP computer working ,but monitor screen stays black. (The computer is 1 year older than screen)
    Problem Solver:
  • 14 Answers
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Posted on Jan 05, 2006
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
Am i able to plug a laptop into the monitor and use this as my screen
No sir you can't do it. just buy a CPU for your monitor. Thank You.......
Feb 26, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
No power after power on and off. No power light indication. What could the problem be?
seems external power supply is shot try with another external power supply e-bay best shot,if power cord plugs directly in monitor then its internal psu might be cheaper to replace than repair
Jan 27, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
No sound coming from speakers
You ether got a short in there or the plug cable has a short ether way this needs to be looked at a quick fix would be to buy seperate speakers.
Sep 24, 2009 | Compaq FP 7317 17" LCD Monitor
Low volume on HP Compaq FP 7317.
You can try using an audio enhancer. That can boost your audio volume a bit.
Check out: http://www.pcauthorities.com/multimedia/how-to-boost-laptop-audio
Works for PC's as well as laptops.
Jules
Jan 12, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Speakers
Sounds like you need to re-install your sound drivers.
Apr 09, 2008 | Compaq FP 7317 17" LCD Monitor
Compaq FP 7317 LCD monitor flickering
try with change the resolution .it will littl ebit help out . othewise show it service personnel. bye
Oct 01, 2007 | Compaq FP 7317 17" LCD Monitor
Fp 7317
My monitors green light stays on, but the screen will come on for a second then goes off
comaq fp737
any ideals
May 15, 2007 | Compaq FP 7317 17" LCD Monitor
Compaq FP 7317 Speaker / Sound Problem
Sounds like the sound card in your computer..
Dec 27, 2006 | Compaq FP 7317 17" LCD Monitor
Compaq fp7317
I suspect that when you reattached the monitor back you might have moved the agp card out of her slot. Check if you have connected properly your monitor to the pc And if the agp is in it's slot properly attached. Hope it helps, good luck!!
Feb 14, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
203 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
