Question about Apple iPod MA446LL/A MP3 Player
Ipod 80gb black
I tried turning on the hold and then off and holding the menu and center button which the manual says is the way to reset your ipod but it still has the same problem can you help wildcat56
  • Anonymous Sep 07, 2008
    my ipod will not install.
    have tried reset option and still not working.
  • wildcat56 Sep 07, 2008
    I reset to factory settings but it says the file or disk is not located I believe do you know what this means?
  • Apple Master
  • 2,794 Answers
The only other solution is to restore your Ipod to factory settings. Reload the songs back up. Make sure the updates are done.
Posted on Sep 06, 2008
  • Tim Babcock
    Tim Babcock Sep 08, 2008
    Take it into Best Buy or The Apple Store and see if the hard drive isn't corrupted.
My iPod Classice 80GB is stuck on pause, it is nearly fully charged but, panel is lite up but will not Forward, Backward, or do any controls from front panel. It is about 3 years old, Help please?
Reset the ipod.
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
if it is not a click wheel then
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Mar 07, 2011 | Audio Players & Recorders
My ipod 80gb is saying apple.com/support/ipod
Try resetting it. Sometimes that's all it needs.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
Feb 12, 2010 | Apple 20gb Ipod Mp3 Player With Click...
My 80gb ipod apple logo want turn off
It is most likely frozen I have the steps below on how to reset the ipod. This should resolve your issue completely.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If this does not resolve your issue please let me know. CHEERS :)
Apr 24, 2009 | Apple iPod MA446LL/A MP3 Player
Need some help
have you tried holding down the menu button and the center vutton at the same time?
Apr 16, 2009 | Apple iPod classic MP3 Player
Locked Ipod Classic 80GB
the switch may be gone but you can try this reset procedure first just to see, first turn on the lock and then turn it off again, next push the menu button and the center button down at the SAME TIME and hold them for at least 50 seconds, then see if it's better
Mar 23, 2009 | Apple iPod classic MP3 Player
Ipod not responding; plays only in my pc
Did you try a hard reset? Hold the center button down while holding the down arrow. the screen will go black and an apple logo will appear . When it reboots try again.
Mar 12, 2009 | Apple iPod classic MP3 Player
Ipod classic 80gb won't open and charge
Oct 15, 2008 | Apple iPod classic MP3 Player
Apple ipod black 80GB
do a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
read more here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
May 30, 2008 | Apple iPod MA446LL/A MP3 Player
Frozen Ipod
what you can do, is take the hold button, and push it back and forth maybe 2 or 3 times, than you hold down the "menu" utton and the center button at the same time for about 10 seconds and you will see it restarting with a black screen and the apple icon in the center than you can let go of the buttons and about 10 seconds it willl become brighter and you will see the icon, then you can get to all of your music or videos and such
Dec 10, 2007 | Apple iPod MA446LL/A MP3 Player
80gb Black Ipod
try holding the menu + center button for about 5 [and up] seconds.
Oct 15, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
60 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
