Question about Texas Instruments TI-83 Plus Calculator
Need the formula for SRS
  • camibami Oct 16, 2008
    I need to know how to pull up a problem when I only need ten solutions and my number is do you put this in the calc w/o just getting one number??/
    Brigadier General:
  • 5,158 Answers
I give simple formula to determine amps:
I (amps or current) =watts/volts.
And with above formula,you can calculate volts and watts too.
Jan 05, 2011 | Friedrich X-Star XQ10L10 20" Air...
What is the dash light srs, in a honda accord 2002 vtec engine 3.0
The SRS, or supplemental restraint system, on your Hondamag-glass_10x10.gif Accord 2002,
Read more: How to Reset a Honda Accord SRS Light |
responsible for deploying the airbag in the event of an accident. If this system is malfunctioning, the airbag may not deploy properly during an accident. However, the system does warn you of a system malfunction. The yellow "SRS" light on the dash will light up, indicating a problem with the system. Once you've fixed the problem, you need to know how to reset the SRS light on your Accord
Jul 12, 2010 | 2002 Honda Accord
96 honda accord airbag module......
does the srs light come on and go off at random times and sometimes stay on if that is so check the srs switch under your seat it try moving round in the seat applying weight in diff locations and see if it goes off and on if so then you might need to replace that switch
Mar 05, 2009 | 1999 Honda Accord
How to use vlookup in openoffice using different sheets
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
Feb 11, 2009 | Microsoft Excel for PC
Random number generation.
you can use the Round function as below - it rounds out the decimal to 0 places, which gives you 5 digits with no commas
Jul 10, 2008 | Microsoft Excel for PC
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Jul 08, 2008 | Microsoft Computers & Internet
Help with simple excel calculations
For cell B1 you can use this (without the quotes) "=A1"
Then for cell A2 and down you don't need a formula, but for B2 you can use this formula. "=(B1+A2)" Then click on that cell and drag the mouse down for as many cells as you want this formula to include and press Control and F keys to fill the formula down the column.
For your second formula, you would type 100 into D1 and in D2 you would use the formula "=D1-E1" (again, no quotes).
Feel free to let me know if you need any more clarification or if I missed something!
Jun 10, 2008 | Microsoft Excel for PC
Excel Formula
Make sure that the cell is formatted as a number, not as text. (Right-click the cell, format cell, number, choose NUMBER.)
Dec 19, 2007 | Microsoft Excel for PC
Random number generators on computers are not really random. They need to be "seeded". If you seed the random number generator with the same seed each time you will generate the same list of numbers. A common technique in computer programming is to seed the random number generator with a value like the number of seconds that has occurred since midnight. This gives you the illusion of real random numbers.
Look up the word "Seed" in your calculator documentation and it will most likely tell you how this is accomplished on the TI calculators.
Nov 20, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
217 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
