Question about Dell Inspiron 6000 Notebook
Keys Hi, I seem to have hit a key on my laptop, I don't know which, and it is now overwriting on the document what I have already written, how can I stop this please?
  • Pat Kelly Sep 06, 2008
    Thanks, using insert didn't solve the problem, I then used my office assistant, who told me to use Tools/Options/Edit and choose what I wanted. Thanks for helping me focus on a solution instead of the problem. P
If you are typing on a word document, look at the bottom of the screen and see if "OVR" is black on the bottom. If so, try hitting the "insert" key and see if it goes away.
Posted on Sep 06, 2008
How restart laptop using f bottons
You don't restart a laptop using the Function Keys (F1 thru F12). You restart the laptop by hitting the power button. The function keys will allow you to boot the laptop in SAFE MODE if you repeatedly hit the F8 key until you see the Safe Mode option after you hit the power button. Function keys will also allow you to change the boot order, go into the BIOS or Setup to change things also. You need to state your problem as to what is going on with your laptop.
Mar 19, 2012 | Computers & Internet
My eee pc 901 doesn't have a working keyboard, someones fiddled with it and now normal keys don't work, but if i press the G key it brings up the goto line box, and all the other keys you'd...
Hi
It seems to be there is pressed button and should be released.
Try with the control keys like ( Ctrl, Alt, Shift, both right and left, and Fn key ).
Press these keys hardly ( not much ) to release them,
Please, Tell us your results.
Good Luck
May 16, 2011 | ASUS Eee PC 901 XP Notebook
When i type a sentence and make a mistake and want to add a new word into my sentence the space bar and any keys i touch type over my existing print. how do i correct this.
You need to toggle your overwrite/insert setting.
All you have to do is hit the "Insert" button on your keyboard. Hitting it once will set your type settings so that new text will be inserted instead of overwriting existing text. Hitting it again will toggle it back.
Mar 28, 2011 | Logitech 967437-0403 Keyboard
In my keyboard there are some letters written in blue how do i access them, and sometimes my keyboard starts giving me the blue keys so i want to know how to activate and deactivate them. Computer:Compaq...
Hi jaywaxxy, you can access the blue keys by pressing and holding the fn key found at the bottom left part of your keyboard. Hope this works :)
Feb 20, 2011 | Computers & Internet
Need to know how to operate the multiple or combination keys functions. For example the J key also has a 1 on it...How do I operate this key using the small number...I need it for math to...
Hello
To use multi functioned keys, you may use following combinations
1. Normal press, just present the the big function written on screen 2. Shift+Key, gives the second function of the key 3. Num Lock on, Gives the numbers written on the key like J gives 1 and so on 4. Fn+Key with Fn color function written on the F1 to F12 keys
Hope this helps
Jan 20, 2011 | Dell Inspiron 1525 Laptop
Keys not working on lato ( you now now what
Check your keyboard for region code settings. Or check the key for the difference on other keys how it reacts on depressing and releasing. Maybe some foreign material that block the key to hit the contact underneath.
Or if this is a rubber type contact, might it is been teared already. Then replacement is an option.
Sep 25, 2009 | Toshiba Satellite P105-S6104 Notebook
I can't find the "FN" key on my wireless logitech S 510 keyboard
buy another keyboard which have FN key... theres a kind of keyboard that are not using FN key...
Jun 16, 2009 | Logitech S 510 (967555) (DH967555)...
HP DV9000 ''G'' ''H'' and backspace keys seem to not work on occasion
Sometimes the simplest things cause us the most grief. A starting point might be to turn the laptop upside down (be careful!). Then, use some compressed air (Dust Off, etc) to blow the keyboard. If there is trash in the keyboard, you might just blow it out -- and fix the problem.
If that doesn't work, you might consider having the keyboard replaced. I normally take them off the laptop and hit them with compressed air from the back before replacing the keyboard. That's an option you should pursue only if you feel comfortable with minor dis-assembly of your laptop.
I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
Char1ieJ
Nov 23, 2008 | HP Pavilion dv9000z Notebook
Six keyboard keys I don't know how to use
Insert: You press this key to toggle either overwrite mode or insert mode when you are typing documents. In overwrite mode, the characters will be replaced where your cursor is in the middle of a sentence and in insert mode, the characters will be added.
PRT SC: Short for print screen. You press this and the computer will take a snapshot of your computer's screen and copy it to the clipboard. Then you can open up paint or word and press CTRL-V to paste that snapshot of your screen as a picture in your document.
HOME: Takes your cursor to the very beginning of a document in a word processor.
SCROLL: Toggles the scroll function in a document.
PG UP: Moves the document you are looking at up a page.
PAUSE: Will pause a list being sent to your screen from the command window.
DELETE: Will delete whatever you have highlighted on your screen
SYS RQ: Check your notebook's information for this.
END: Will take your cursor to the end of the current line, paragraph, or document.
NUM LK: will turn on the numberlock function, allowing you to use the right side ofyour keyboard like a numberpad.
Thanks and please take a moment to rate as fixya.
Jul 06, 2008 | HP Compaq nx6110 Notebook
Dell Inspiron 6000 Notebook Logo
70 people viewed this question
Alun Cox
