Question about Polk Audio PSW10 Subwoofer
PSW 10 Not working
Have not used system for a few months , PSW will not come on , tried unplugging and then re connecting , still nothing. Has been plugged in ant set on auto since new , @ 2 years. Would appreciate any help. Thanks.
  • irishrudd Jan 04, 2009
    I'm havin the same issue. My PSW 10 Sub Woofer has been set to Auto since I bought it. The power has gone out. I also tried plugging it into another outlet with no positive results.
  • Anonymous Jan 06, 2009
    Me, too. Same issues. Worked fine. All of a sudden, no power, regardless of the outlet.
    Any answers world?
Your 2A 250v slow-blow fuse is blown, located under the back pannel. Mine just did the same thing. Problem is the problem with my PSW10 goes beyond the fuse. I have contacted Polk tech support to help me trouble shoot.
Posted on Jan 12, 2009
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
JLB PSW-D110 Subwoofer Issues
Hummmm is from Output amplifier and you need to replace it because power supply blow it too.
Sep 09, 2008 | JBL PSW-D110 Speaker
Toshiba A105 Laptop will not come on
Kindly try to remove the battery from the system and connect the system only with the power adapter.
Try to turn on the system. Keep the power button pressed for few seconds.
Please revert with your helpful comments.
Thank you for choosing Fixya
May 27, 2010 | Toshiba Satellite A105 Notebook
I'm trying to connect the phone to my pc via bluetooth.I'm prompted for a password, but the phone's psw is not recognized by the pc, and the pc's psw is not recognized by the phone.Thus pairing does not...
The password that the phone or the PC is looking is the Bluetooth PIN code.
You may try pairing the phone again to the computer and use either 1234 or 0000.
If you use 1234 on your phone, you should use the same PIN code to the computer.
Feb 20, 2010 | Nokia Classic 2700 Cell Phone
ThinkPad 600 System Board error
Have you tried using the reset jumper on the motherboard? I had a PC a few months ago that I had to replace the battery in. I eventually had to use the clear CMOS jumper and the reset BIOS jumper to get the computer to load to BIOS normally. Remember, if you don't have to correct the date and time, then the BIOS has not been reset. Sometimes it is a good idea to leave the PC off and unplugged for about 10-15 minutes to let the capacitors drain down. By doing this after reseting the PC, it gives you a clean cold boot (meaning there is nothing stored and nothing has had power before a reboot).
Nov 10, 2009 | IBM (30L2872) for ThinkPad 600E 2645-55x...
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
JBL subwoofer PSW-D115
Hi Im a Certified Repair technician, I seen few problems with this unit, there is a amplifier module inside this unit, is really hard to find since JBL discontinued this almost immediately.
Sorry no really worth to bother........
Apr 10, 2009 | JBL PSW-D112 Speaker
Unresponsive RCA Digital Converter
You may need to change your antenna for digital reception. Make sure the outlet you are using for the converter box has power to it.if that does not solve it you may have defective box.
biigg53566
Feb 18, 2009 | Insignia Digital-to-Analog Converter for...
Radio does not work
If the unit is only a few months old, returnit for warranty repair or exchange. A power fail should not effect it. Try unplugging it for a few hours to force a system reset. If that fails to resolve the problem, have it serviced under warranty.
Dan
Jun 03, 2008 | Audio Players & Recorders
Polk Audio PSW10 Subwoofer Logo
764 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
