Question about Vtech VMix Gz2456 Cordless Phone
Caller can't hear my vocie when I use hand set
All things are working ok in the handset and base unit. However, when I speak throug the handset, other person (caller) can hear my voice but I cann't hear their voice. If I use speaker phone then I can hear the boice and caller can also hear my voice.
  • 5 more comments
  • Anonymous Mar 16, 2014
    When someone phones me and I answer the call, the person calling cannot hear me speaking. How do I rectify this?
  • Anonymous Mar 21, 2014
    The person talking to me sounds really loud.
  • Anonymous Mar 27, 2014
    I can hear my own voice on the handset
    the person that I am speaking to can hear their own voice
  • Anonymous Mar 31, 2014
    after trying to reset handset,handset says out of range and continues to say searching ,also on handsets I can hear my voice
    Have tryed to reset the hand set and it still says out of range and i have put it near each base
  • Anonymous Apr 01, 2014
    my hand set has been flashing searching on the caller id for the past 10 hours
    Champion:
  • 277 Answers
Probly it fell or something the speaker needs replacing
Posted on Jan 31, 2006
Cordless handset. Why can't callers hear me?
normally, it is because the Mute button is pressed, but you say they can hear you, but not very loud? Make sure the bottom of the phone is close to your mouth. Look in the mirror. Also find the volume setting on the phone, and turn it up full. This is generally accessed via and options button, scroll through until you find 'Volume' and then press the up arrow.
Nov 19, 2015 | Lands Phones
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
Jul 18, 2011 | Plantronics CS70 Wireless Headset
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
Cannot get a dial tone or hear caller on one of the handsets, but can hear it ring and the caller can hear me. The other handset is fine.
try unpluggjng base unit from power supply and then let handset unit reset to relocate the base unit.
Feb 11, 2010 | Panasonic KX-TG5632 Phone
I can hear caller on handset but they cannot hear me?
We just had the same problem with our AT&T 2462 hand sets. They simultaneously stopped transmitting, and though we could hear the caller, no one could hear us on the other end of the line. We unplugged the base from the power source, took the batteries out of the hand sets, waited 20 seconds, then plugged everything back in and they worked just fine. Hope this helps.
May 03, 2009 | AT&T E2562 Cordless Phone
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Callers cannot hear me with one handset
Try them in intercom mode. If the flaky unit still does not work, the something along the microphone circuitry is likely dead. If its in warranty, get a replacement from the store or manufacturer.
Mar 03, 2009 | Panasonic KX-TG1033S Cordless Phone
Distortion Problem with Pink Nokia7373
This is a Network Service Provider problem.
Apr 01, 2008 | Nokia 7373 Cellular Phone
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Vtech VMix Gz2456 Cordless Phone Logo
1,949 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
