Question about GE DBSR453EBWW Electric Dryer
GE Dryer Mod DDE8040l heater coils
New coils replaced but coils luke warm. Won't heat.
  • 172 Answers
Check your voltage to the dryer, make sure you have the required 220 volts. If you are only getting 110 volts the dryer would run but not heat. So check the breaker or fuse box first,, then check the plug for proper voltage, then the terminal block to make sure you do not have a wired burned off.. after that it would most likely a high limit thermostat. Good luck. I hope this will fixYa. and dont forget to rate me. Thanks
Posted on Sep 30, 2008
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ... > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - ...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
Jan 27, 2016 | 2000 Chrysler 300M
My peugeot 308 2012 heaters are not warmin up properly.Its fine when the car is stationary but when its driven the oil temp gauge cools right down to zero?? and heaters are luke warm at best.
In order to answer this more specifically we would need the type of car and its year. However most heaters have a heating coil that is activated by the cars coolant. the warm water flows through those coils and dissipates its heat to the interior portion of the car. So, I would look into checking your coolant and your cars heating coil. Although heating coils are usually very hard to access. I may be incorrect in this, I am basing this answer off of my 1994 miata and my 1998 toyota 4runner.
Dec 13, 2015 | Cars & Trucks
Dryer does not get real hot just luke warm
Sounds like one of the heating coils has broken. Replacement usually requires complete dismantlement of the unit to get at the back of the barrel.
Mar 04, 2011 | Kenmore 82722 Electric Portable Dryer
I have a ge smart water electric water heater and
does it not have adjustments for heat settings. I thought these were smart as in maintaining heat with demand
Mar 05, 2010 | General Electric GE SmartWater Household...
New GE Dryer Not Heating
Sounds like the HEATER COIL is bad or not connected properly on the inside. I would call the place where you purchased and exchange it ASAP.
May 29, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Luke warm water on sanitize cycle, why?
remove lower kick panel and check wire connections to heater. 2 wires go to heater terminals and a harness connector goes to temp sensor in middle of heat terminals. may be green ground connection on another term. use multimeter and check resistence on heater. during cycle heater will take time to heat.
Mar 16, 2009 | GE WBVH6240F Front Load Washer
Heater is blowing luke warm heat
Double checking, does fun shut off when switched to heat instead of defrost?
Jan 24, 2009 | 1993 Ford Ranger SuperCab
Heater will only heat spa water to luke warm.
sounds like it may be the thermostat on the heater. You are correct to check the filter first. if it is clean then it is probably the thermostat
Dec 19, 2008 | Jandy Laars Lt 250,000 Btu Heater
GE DBSR453EBWW Electric Dryer Logo
79 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
