I had the same problem. Turned out the Child Lock was on. Push the Child Lock button on the remote (it's below the 0 key) and that should fix the problem.
DVD starts and about a minute or two the picture freezes and you can't even eject the disc. Tried to...
(More)
DVD starts and about a minute or two the picture freezes and you can't even eject the disc. Tried to get dvd out after I unplug the player and it resets itself.
dvd player freezes and stops working I have to unplug and hope it resets. tried to clean player with...
(More)
dvd player freezes and stops working I have to unplug and hope it resets. tried to clean player with dvd Dr laser lens cleaner, but I have same freezing of dvd
How do I do the reverse? I want to copy a VHS tape to DVD. Also, can I do this w/o connecting to a...
(More)
How do I do the reverse? I want to copy a VHS tape to DVD. Also, can I do this w/o connecting to a TV? Thank you for your attention to this!
Recently had Charter Communications install digital cable now DVD or VCR will not work - cable...
(More)
Recently had Charter Communications install digital cable now DVD or VCR will not work - cable company said that my machine may need to be reset??? Machine will come on, I hit play, disc and/or tape is playing but not on the TV.
You can no longer set up a timed recording to the VCR after the digital conversion that took place...
(More)
You can no longer set up a timed recording to the VCR after the digital conversion that took place on June 12, 2009. After I ran the channel reprogram the system does not recognize any of the digital channels. There doesn't seem to be any way to get to the ??.001 identity numbers associated with the digital channels over the air. Curt
