Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Pentium4 computer windows 2000 profesional upgraded to XP. Can not install printer because spooler service is not running. How do I start service .I want to install a Lexmark printer and it says I cant because the service is not supported? HELP.
No. It still says can not install service on local computer. Thanks anyway
Posted on Sep 08, 2008
  • 33 Answers
To start print spooler service, go to start > run > services.msc then press enter. scroll down the list to find print spooler, then right-click then click on start. You need to have it automatically start in the future, so you have to right-click > properties > startup type > change to automatic. Then try reinstalling your printer if necessary.
Posted on Sep 06, 2008
Printing sitting in queue wont print
The print spooler may not be working.
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 28, 2012 | Brother MFC-290C Printer
Im not very tech minded. but i need to restart a print spooler in order to instal an epson printer
You'll need to use an administrator account to do this, click on start, go to computer right-click, choose manage, double click Services & Applications, then click on Services, highlight any one of the services then push P on your keyboard, now look for print spooler, right click and choose start.
Sep 13, 2011 | Acer Aspire 5742Z-4200 Notebook
Printer can not print as it says spooler is not functioning
If you're running on windows 2000/XP/Vista you need to start the print spooler service.
1. click Start - Control Panel - Administrative Tools - Services.
2. In The Name Column look for the one that says "Print Spooler", right-click on it and click Start or Restart.
Nov 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Not find print spooler in my service
Try going to start-->run and type cmd to get to command prompt
From there type:
net stop spooler
net start spooler
Close the window and see if it will install then
Jul 11, 2009 | Microsoft Windows XP Professional
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP photosmart all-in-one 4100 series
The issue is with the print spooler. If the operating system is XP then click on start >> run >> type services.msc >> the services window opens, now locate the print spooler and right click on it and select stop(if it is started) then again right click on it and then click on start. Now the spooler service will start, then try installing the all-in-one software.
Aug 02, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
Print spooler
Click on Start Click on run Make sure the run line is clear Type services.msc You will see a list of services Make sure all items below are set to automactic To make the changes double click on each item line change to automactic if diabled. Then click apply when you are done. Printer Spooler LexBce Server Remote Procedure CallRPC) Restart the computer Hope This helps
Sep 17, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
