Question about Canon Rebel XT / EOS 350D Digital Camera
400d It gives me erro 99 when i attached a speedlit it says remove battle and reinstore
  • 56 Answers
This is a very common problem, and usually to do with connection or communication problems between the camera and the speedlight/lense/or other device. Try cleaning the hotshoe contacts and make sure that the speedlight is firmly on the camera. Otherwise it may be an internal fault with the speedligh but this is not likely.
Cheers
Emmanuel
Posted on Sep 11, 2008
Error 99
Hi. I can give you some advices, but be very careful!
What do you have to do?
Clean (very carefully) the 8 gold color lens contact pins on the camera body
lens mount. Be sure that you're doing good.
Remove your CF memory card and take out the camera's both batteries (the main one and the smaller date/time battery).
While the batteries are removed, turn on the camera and let it for like 5 minutes.
Turn your camera off and attach your CF memory card & your batteris where it belongs. Also, re-attach the lens. Turn your camera on.
You can also update your firmware!
I hope it works!
May 20, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon speedlite 430 EZ does not match with canon 400 D digital camera how to use the same flash with 400 D.
You can't. The metering systems are incompatable. You must use the EX range with the 400D, such as 430EX or 580EX (versions I or II)
Feb 25, 2009 | Canon EOS 400D Digital Camera
I have error 99 in my camera canon 400d
Ifd the camera is only 3 months old - return it for replacement
Sep 01, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error 99 in EOS 400D
Here is a link which may help you.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=9598105
It may be that the contacts on the lens is dirty, follow the directions, by using a clean pencil eraser (I would also suggest to use alcohol and clean the contacts after using the eraser). Also to remove the date button battery and the other batteries, then turn on the camera (with all batteries removed).
Then put the batteries back in.
Jul 23, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Won't Work As Slave With Canon EOS 400D
Speedlites with the suffix "EZ" are never compatible with the digital EOS line-up. All models that do work are named "EX" (420, 430, 550, 580EX et al.)
Apr 03, 2008 | Canon Speedlite 540EZ TTL Flash
Speedlite 540EZ and EOS 400D
540EZ will not work on digital Canons in auto reading mode. It will only work on manual flash settings.
Mar 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Error 99 is a general fatal error.
which includes the problems above mentioned by Q4SteveB but also many others.
It can be caused by a dicky shutter, problems with the CF card interface.
If cleaning and trying a different lens has not worked. Not definitive but as a rule of thumb...
If it letting you take one picture then giving error 99.. and the picture is saved to the card (but may just be black) this is most likely the shutter needs replacing..
If it takes a picture and gives error 99 but there is no picture on the card or the picture is 0KB its a CF interface problem.
If you get an error 99 when you plug in the USB its a USB interface error, you can try a different cable but unfortunately in most cases if another lens or cable wont work it needs repair
Feb 22, 2008 | Canon EOS 30D Body Only Digital Camera
Xti and Speedlite 200E
The only way to solve the problem I see is to turn the flash into non-TTL one. It can be easy done by opening four screws at the connector side of the flash, unsoldering or cutting the BROWN line and closing the connector back. The AF assist led will work.
That I did on my 200E with Canon 400D camera and all works file.
Enjoy!
Jan 06, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Jul 31, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
