Question about Kenwood KDC-716S CD Player
Replacing the facepale
How do I go about replacing the faceplate ?
I got the stereo used and it opens/shuts with some help and plays music so I figured I would replace the faceplate.
I can see that the top left pin to the FP has the tip broke off.
I dont have the manual to read so I dont know how to remove the faceplate.
TIA for any help.
  • dchopp Sep 24, 2008
    Guess I'll answer my own question in case someone else has the same problem.
    I located the manual at Kenwood USA (online).
    It was not correct it says Holding the center of the faceplate, pull it out during the period which you have set in the "Time setting for removing the faceplate" in the menu.
    When removing the faceplate, pull it out only when it is fully open.
    Well you can pull on it if you like but you wont get it off the head unit.
    When the faceplate is open during the time setting you need to use something like a paper clip and stick it in the hole on the bottom edge of the face plate and slide it to the side.
    The faceplate will now come right off, just as it should.
That hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Posted on Oct 25, 2008
I want to be able to listen to music in my car using my USB Sandisk Cruzer but my car only accepts an iPhone plug into an Aux hole. Is there anyway I can by pass this
You might be able to using one of these usb to audio lead you can also get these just as adaptors without the need to for a lead http://www.ebay.com.au/itm/3-5mm-Jack-Plug-to-USB-Male-MP3-Mp4-Audio-Data-Cable-White-/330831058200?pt=AU_Electronics_Portable_Audio_Accessories&hash=item4d07115518 $4.12 3.5mm Jack Plug to USB Male MP3 Mp4 Audio Data Cable White or http://www.ebay.com.au/itm/USB-Male-to-3-5mm-Audio-Stereo-Headphone-Jack-Plug-Cable-For-MP3-MP4-Black-/160733005608?pt=UK_Computing_Sound_Vision_Audio_Cables_Adapters&hash=item256c6f0728 $1.50 free postage You might get these on Ebay im not sure which country you are in this might guide you to one You could get this on Ebay if you dont have an account you will need to create one. https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also Add your Postal Adress also Add a PayPal account. Click on the Ebay tab on top of page from the drop down list you will see specific pages. On left hand side on Ebay summary page you will see the PayPal link. when you get to the PayPal login page at the bottom you will see new to paypal sign up tab. Paypal to create an account PayPal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a Postal Adress. Be very specific when you type in the search. Always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. Music has become more mobile than ever before, as numerous devices can store and play music on-the-go. Companies have developed car audio decks that incorporate USB ports in the faceplate. This allows flash drives to be plugged into the deck, and music on the drive to be played. Flash drive format issues are minimal, considering nearly all flash drives are formatted in the FAT32 file system by default. FAT32 is readable by any operating system, or stereo deck with a USB por
Determine if the stereo deck in the vehicle is capable of playing music off a USB flash drive. Read the stereo deck user's manual, or inspect the deck faceplate for a USB port. Plug a USB flash drive into an available USB port on a computer. Check the drive to make sure there is enough available space for music files. Using Windows, double-click the desktop icon labeled "My Computer." Right-click the flash drive icon, and select "Properties." Capacity will be shown. Using Mac, click the flash drive icon once it appears on the desktop. Click "File" in the top menu bar, then click "Get Info." A dialog box appears, and capacity is listed. Drag and drop any desired music files onto the flash drive. Be sure the files are in .mp3 format. Although some stereo decks are capable of playing other music types, the .mp3 extension is universal and all decks will play it. Spend a short amount of time organizing the files into folders. Organize by genre, artist, or create mixed playlists. Selecting music while driving will become much less distracting. Close the drive window, and safely eject the flash drive from the computer. Plug the flash drive into the stereo deck of the vehicle. Select the USB port as the music source, via the stereo deck. Read the manufacturer's user manual if unsure of how to change the source. Adjust the volume, listen, and enjoy. Hope this helps.
Jan 15, 2013 | SanDisk Cruzer Electronics - Others
Burned CD with no label is stuck in my car stereo Pioneer model deh-p9200r. It plays fine, but how can I get the CD out?
When you remove the faceplate you will see a tiny small hole in the deck. Insert an open paperclip to remove the CD. PLEASE let me know if this helps
Jan 19, 2011 | Pioneer DEH-P9200R CD Player
My car stereo shuts off while driving and playing
if you have had the head unit for long, it might be over heating and going into safe mode so it doesn't get to hot. This happened to my amp and i never did anything until it stopped working all together. so my guess would be just to get another head unit or get some type of cooling system.
Sep 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Sometimes fce plate wont come on, but music still plays.
had the same problem with a pioneer i took a qtip and some rubbing alcohol and cleaned the gold colored connecters on the face and radio and worked ever sine.
Mar 01, 2009 | Pioneer DEH-P6600 CD Player
Accidently removed the tiny screws behind faceplate
It could just be a plastic clip that broke.Most of the car stereo's ive taken apart only have a thin ribbon of wires that run into the contacts that your face plate connects to.If you actually took screws out of the faceplate then id put them back in and put it back into your stereo and see if it illuminates properly,if it does not then id search on E-BAY or contact pioneer and buy a replacement but most the time it would be cheaper to just buy new stereo.You might want to be more specific with the area you took screws out of,the way im reading it sounds like you unscrewed the screws in the face dock, not the faceplate.Hope this helps.
Dec 18, 2008 | Pioneer DEH-P3700MP CD Player
Faceplate not working
Try disconnecting the unit completely.
Nov 09, 2007 | Sony CDX-F7700 CD Player
Kenwood KDC-716S CD Player Logo
170 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
