Question about RCA D52130 52" Rear Projection Television
Removing the protective screen to clean
I need to remove the protective screen to clean the "actual" screen for my TV
  • stump1733 Sep 27, 2008
    I need to know how the front pops off to remove the protective lense in front of the screen.
The speaker grill pulls off, you will find the screws under there
Posted on Oct 04, 2008
  • Teresa Campbell
    Teresa Campbell Dec 09, 2011
    be careful of wires clean only the lens and dust gently do not wipe the refective tin it will scratch easily
Monitor cleaning & hard glass protective layer removal
Of all the LCD/LED monitors I have used, I have not seen one that has a removable glass face.
Nov 10, 2013 | AOC International 23" Wide Lcd 1920x1080...
I have the newest version of this plsma TV. It is one month old. I tried to clean some areas of the screen with a micro fiber cloth and a dab of windex in 1 corner of the cloth, not realizing that the...
You have damaged the outer protective screen. Only replacement will fix. Water only on a damp cloth should be used to clean. However, the outer screen can be changed. Since the tv is almost new you will have to contact Samsung at through customer service at 1-800-627-4368 9AM to 8:30PM Eastern time. When changing the outer screen be sure to never touch the inner screen after removal. You have to take the back off the set to get to the screws holding the baziel or "plastic frame" to remove the outer screen. I have never taken a screen off of a set that new so I advise you exercise patience when removing. Have the product code ready for customer service to locate the proper protective screen. And serial number.
Oct 23, 2011 | Samsung PN64D7000 3D Plasma TV
How to fix a big scratch on a projection tv screen
Is it the screen itself or the protective screen that is scratched. If it's the protective screen, then you can just remove that, but be warned the lenticular screen is now prone to scratches from kids, dogs or a clumsy significant other. But if you feel comfortable with no one bumping into it, then you can remove the protective screen and actually get a better picture quality with no glare.
If it's the actual lenticular screen (one behind the protective screen) then your in trouble and it will cost a pretty penny to get fixed. You can switch it out yourself once you buy a new one, but have two people handy, the instructions on how to replace should be in the owners manual.
Jul 19, 2009 | LG 30FZ4D TV
Why not remove the screen assy and see if you can clean it?
Remove the speaker grill assy and remove the screws along the bottom edge of the screen assy. Pull the screen assy up and off and lay it on a clean sheet with the outside of the screen assy face down. Remove the screws that fasten the screen bracket assys in place and remove the screen brackets.
Your TV actually has either 2 or 3 screens. You can carefully lift them off the screen frame. Separate them and clean them using a solution of luke warm water and a few drops of dish washing liquid on a soft cloth towel. Wipe immediately with a dry towel. ( be sure to note the order the screens are in and keep the smae side of each screen as it was originally. By the way, replacing the screens is expensive. The 2 that do the work, the lenticular screen and the fresnel lens can cost up to $300 a piece, the third, a clear, protective screen can cost $100-150.
Feb 18, 2009 | RCA P52926 52" Rear Projection Television
Removing the protective screen on our Pioneer SD-532HD5
Pop the bottom front cover off (that is over the speakers) first. This will expose 2 brackets that hold the moulding around the screen in place. Un-screw the brackets enough so you can get the moulding off and take it off. Once the moulding off you will see the brackets that hold the actual screen in place. Loosen these brackets and VERY carefully remove the screen (it will wobble and bend so I would recommend 2 people do this). Lay the screen down on a soft surface that will not scratch it. Clean and re-install screen, tighten brackets, re-install moulding, tighten brackets and pop the speaker cover back on.
Nov 11, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Cleanng the projection mirror
remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Sep 18, 2008 | Mitsubishi VS-45603 45" Rear Projection...
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
RCA D52130 52" Rear Projection Television Logo
142 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
