Question about Philips Magnavox 9P6034C 60" Rear Projection Television
When sound & picture finally comes on the picture is pink and in the middle of the screen
After cycling the power button several times ( each time the the internal sound of the TV is heard but no picture or sound) the sound & picture finally comes on. The sound is okay but the picture is pink and in the middle of the screen. After several minutes the picture begins to expand and become more clear and visable. When it begins to look normal it will shink in and out continuously.
  • Philips Master
  • 3,459 Answers
This is a common problem with this model. The site has a chip kit to fix the no audio/video and video shrinking problem.
Posted on Sep 07, 2008
LG 50PZ750-UG Intermittent picture and sound.
It is likely the best thing to do here money wise is replace the TV.
Aug 25, 2016 | LG Televison & Video
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV clicking on and off with colored screens and noises, not power supply capacitors this time.
Sounds like a main board fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 20, 2014 | Samsung LN46A630 46 in. LCD HDTV
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Pink Leapster2 beeps and wont go pass warning page
One suggestion; Place in a Wal-Mart bag , drive to the store and go to customer service and ask for a refund(if you have the receipt) or ask for an exchange. Wal-Mart is good on that. Good luck!
Jul 09, 2009 | LeapFrog Leapster 2 Learning System
My tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Apr 24, 2009 | Televison & Video
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
Blank screen
These tvs are known for bad power supply capacitors. Try power cycling the tv several times (8-10) to see if it finally comes up. Four flashes indicates a power supply problem or a deflection problem, usually it is the first. Take the set into a shop if you are not an electronics technician, as these are dangerous areas to work on. Otherwise, use a capacitor checker to test the caps, starting with the main supply caps which are usually 200v. I've found these to be low by 200uf. Also, check the 1000uf and 2200 uf caps. These will be low by 100 - 200uf.
It could be a flyback or deflection problem, but check those caps first.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
403 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
