This is not a projection tv.
The picture is drawing in on both ends. It has gradually gone from l inch to 4 inches on each side.
  • 19,396 Answers
I report my posts from other thread:
start going to the video settings menu and do a reset check page 33 of user manual here .
If you are using the TV connected to a computer, see also PC mode control to set display width at page 62
Try doing the reset suggested above, see if they work, leave also the TV unplugged for few hours tonight.
Generally, if the bands appear only for some times , then image expands regularly it is a faulty IC or capacitor, that works fine only after it warms up.
I work on PC monitors etc.I have not serviced your model yet, and I don't have the service manual to follow the troubleshooting diagrams to locate faulty area on the board, test parts and find defective one.
If you want to DIY here is the service manual.
Here you get all parts for your TV.
If you want to call a technician there is a number listed at the end of the user manual.
If I find any free schematics I will post here.
Posted on Sep 06, 2008
Cloudy
Sounds like a issue or problem with the optical light engine in the set, it is of course the most expensive part.
Dec 12, 2012 | Mitsubishi WD-73827 73" HDTV DLP TV
Black spots on TV when watching sports etc that have white in the picture. The black spots are showing up on the ice for instance (Hockey) all over the TV.
I SUGGEST CLEANING THE LENS ASSEMBLY. IF YOU LOOK ON THE SIDE OF THE TV CABINET YOU WILL A SMALL SQUARE THAT IS ABOUT 4 INCHES BY 6 INCHES HELD IN WITH ONE SCREW IF YOU LOOSEN THAT SCREW YOU WILL BE ABLE TO GET INTO THE CABINET OF THE TV AND CLEAN THE LENS GOOD LUCK
Jan 06, 2011 | JVC HD-52G786 52" Rear Projection HDTV
What is causing my picture to darken on my samsung 60 inch dlp tv
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
Jan 04, 2011 | Samsung HL-S6767W DLP TV
Three separate images about 4-5 inch apart on my TV
Symptoms shows TV has problem of faliure of convergence out ICs. (2 ICs in TV) and need to be replaced.Let me know do you want to repair it at your own? ...
... if yes, it is necessary to have experience of TV repair and basic electronics knowledge.
Nov 23, 2008 | Sony KP-51WS500 51" Rear Projection...
Two green lines on bottom left corner
Sounds like a convergance issue. I would have a tech set the convergance for you if you have not done it before, it can be tricky and you could make worse.
May 11, 2008 | Toshiba 65HM167 65" Projection Television
Rca 52 inch projection looks like 3-d movie
Open up the back, the convergence ICs are large and attached to a heat sink. They should be marked STKxxx. In most cases, replacing the ICs is enough. Sometimes the feeder resistor fails because of too much current draw. Change the ICs before looking for more parts. Also, try resoldering the ICs. Bad connections can cause this problem as well.
Dan
Apr 09, 2008 | Televison & Video
46 inch rear projection tv bulb replacement model number 46gw944
The tubes are most likely not the trouble,sounds like you have a bad screen asy part number is 204809,must use the generic,Thomson discontuned this part.
Feb 05, 2008 | GE 46GW945 46" Rear Projection Television
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Feb 05, 2008 | Televison & Video
Samsung hcl552w picture leans in on top and bottom
bad convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 09, 2008 | Samsung HCL552W 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
