Question about HP Compaq 6720s Notebook
Hard drive Upgrade
My HP Compaq 6720s Notebook only has an 80GB Hard Drive! :(
Would it be possible to upgrade it??
And where, i live in Doncaster, UK
    President:
  • 2,961 Answers
Yes it would, but this is not as easy as it sounds, desktop pc's are easy to do but not notebooks, as you may have a restorew partition on your sytem to recover your pc if it crashes.
your option would be to buy an external usb pocket drive, as they can also be used on other pc's and you are able to run programmes from them on any pc using the software provided and they are cheap nowadays
See here for an example
Posted on Sep 08, 2008
On the BIOS set up, it will show HDD (none) but if i return the old one the system will detect it.
This model laptop was installed with a 60Gb hard disk. When you installed a much larger hard disk the BIOS could not detect this hard drive.
Check the HP/Compac WEB site foe a possible BIOS upgrade that can support a large hard drive. Otherwise try a hard drive 120Gb or smaller.
Nov 10, 2012 | Compaq Presario 2190US Notebook
I can't format my HP Compaq 6720s Notebook,win xp say can not hdd drive ,but i'll get new hdd
The reason XP cannot detect the hard drive is because thr hard drive in this model HP is a SATA hard drive and the Windows XP installation CD does not have the SATA controllers on this CD.
To install XP on a SATA hard drive, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 03, 2011 | HP Compaq 6720s Notebook
Hp 6720s it says non-system disk or disk error
Hi,to confirm if your drive is still functional please go to BIOS,by press F10 when the system has just been switched on,go to Diagnostics on the Bios Menu,select Hard Disk test to verify the state of of your drive,if after test drive is still ok back-up files and format,if not replace drive.
Jan 08, 2011 | HP Compaq 6720s Notebook
Hp compaq 6720s says pxe - e61
PXE is the boot option from a bootable network card, so basically the BIOS isn't seeing any of your bootable drives and going trying to PXE-boot off your network. Check the boot options in your BIOS and make sure your drives are detected by the BIOS. If they are not listed, then the drive has likely gone bad.
May 05, 2010 | HP Compaq 6720s PC Notebook
Replacment sound card for hp compaq 6720s.
Your system does not have, in a soundcard per se. It uses integrated audio that is capable of delivering the features and high-end performance of an add-in audio card.
Ergo, assuming you are lacking sound, you can mosey on to the HP site and look for what they refer to as a 'softpaq'. Use the HP search engine on their website (rather pertinent results if i may say so myself).
1. Download the SoftPaq .EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
Jan 19, 2010 | HP Compaq 6720s PC Notebook
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
Unlock dvd region
There may be a firmware upgrade that make your DVD region free, but if you make a mistake or install the wrong firmware upgrade then the DVD will be a piece of junk. You will need to Google search for DVD firmware upgrades for your model DVD.
The best way to view DVDs from other regions is to install a piece of software that defeats the region code. I use a program called DVD-RegionFree from
www.dvdidle.com
There are possibly other programs available, again Google search for them.
Dec 31, 2008 | HP Compaq 6720s PC Notebook
RAM UPGRADE FOR HP COMPAQ 6720s
Well, your hard drive is ok.
Oct 04, 2008 | Computers & Internet
The speed of your computer is determined by the memory capacity, the hdd storage capacity (that means that if the hard drive is full of data your computer becomes low - not about the size of your hard drive) and your processor speed.
In your case I recommend:
1) A good cleaning,
2) Be sure that your computer is not virus or spyware infected
3) Get rid of those programs that you are not using.
4) Disable the programs that are running on the background
Sure after that your computer will become faster.
Your memory capacity is good enough to your normal duties (above described)
Oct 03, 2008 | Compaq Computers & Internet
HP Compaq 6720s Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
