Question about Gateway GMAX 2100 Computer Speakers
POPPING NOISE I TURN THEM ON AND EVERY ONCE COUPLE SECONDS A LOUD POPPING NOISE HAPPENS.....HELP PLEASE...THX
  • 1 more comment
  • nombre12 Nov 17, 2008
    i have the same problem and i tried pluging in my headphones to the jack and they make the same noise. is there something wrong with my mother board perhaps?
  • Anonymous Mar 05, 2009
    I'm having the same exact problem. It's kind of scary. When I keep the speakers turned on but unplug it from my computer, it still goes on.
  • prfloyd Mar 10, 2009
    My laptop (HP dv6000) started doing this when I had to put a new hard drive in. It happens almost everytime I navigate on the internet but at random other times as well. Very disconcerting when you've already lost one hard drive.
Same popping sound problem with my Gateway computer and GMAX 2100 speakers. First the popping was sporadic, then it kept getting worse. The problem was in the Creative Sound Blaster Audigy 2 ZS board. I replaced it with a less expensive Audigy SE board and the problem is fixed, sound is great. I looked closely at the old board and it looks like there were defects in 3 of the solder connections on the back of the board. It looked like corrosion in the solder or something was shoring a few of the posts. CC
Posted on Sep 26, 2007
There is a fault with this model that Logitech know about. It is a design fault regarding improper shielding. See this link for more info: http://forums.logitech.com/logitech/board/message?board.id=51_speakers&message.id=811&view=by_date_ascending&page=1
Posted on Apr 15, 2007
The problem was caused by a regurater electrolytic capacitor that only 16 volt rate while the real supplied direct voltage to it, is 27 volt. So its electrolyte leaked and causing output voltage that feed power ic to be ripples. the solution is replacing that capacitor with 35 volt rate or more. if your power ics didnot damage yet ,this would solve the problem.
Posted on Apr 10, 2007
    Scholar:
  • 48 Answers
It is possible that either the speakers or the sound card have an internal fault. The best way to isolate this type of problem is to use a different audio source than your sound card uses in order to test the speakers. You can use a portable CD player, the headphone jack on your CD or DVD drive, or the headphone jack on your VCR, for example. In some instances, the speakers have been known to pick up noise from an external source. This is difficult to isolate as just about every electrical device in your house/office gives off some amount of radio frequency (RF) or electromagnetic interference (EMI) signals. Some of the more common items that can cause noise are: Your monitor Fluorescent lights An uninterruptable power supply (UPS) The computer itself Fans Turn off as many of these devices as possible before you test your speakers. Also, if your speakers are plugged into a power strip or UPS, try plugging them directly into the wall outlet instead. Good luck
Posted on Jan 04, 2006
Loud popping noise and spark coming from red projector
I would guess you have a High Voltage Leak at the Anode Lead Cap where it Mounts to the CRT. This is not a area to mess with You are better off calling a professional to fix it. It may be a little difficult to confirm if it is a intermittent problem.
Hope this helps,
Skyassoc
Jul 04, 2009 | Hitachi 51F59 51" HDTV Projection...
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
02 silverado gas tank popping noise after startup & shutdown
It could just be the heat shield around your exhaust expanding and contracting again when your engine cools down. Sounds like a tin can type of popping noise?? If it is that's the heat sheild from the engine that protect's the spark plug wire and around under the truck cabin. Good luck and hope you find where the noise is coming from.
Apr 06, 2009 | 1999 Chevrolet K1500
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
89 sedan deville makes popping noise while off.
It could be related to the exhaust pipes/ and or shields cooling down
Feb 04, 2009 | 1989 Cadillac Sedan DeVille
Amana Mod # ABB2223DEB Refrigerator
Try damper part number W10167268 from Whirlpool. They re-engineered the part, it's works different. Whirlpool issued a bulletin to servicers, but won't cover it under warranty (I have tried for many customers) "A bulletin is NOT a recall"
Jun 03, 2008 | Refrigerators
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Tv making popping sound
Turn down the volume and see if you still hear it,a loud pop or snap could be high voltage call your servicer in your area ASAP
while its under warranty and have him check the high voltage circuits for a intermittenting pop or snap.And have the model # ready!! Good Luck!
Dec 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Gateway GMAX 2100 Computer Speakers Logo
4,126 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
