Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso 24082 error code CE
I press start. It acts like it wants to come on. I here the water run through the machine. I hear different componance getting read. Then silence. Machine beeps, flashes and red error code reads CE. All this takes place in about 3 to 5seconds. I go get my trouble shooting guide and it says Error Code CE means Communication Error.I called out a repairman for a reputable company. he said three fifty buck, and told me it is one of the circit boards ; that I would be better buying a new one. I called sears parts dept. they tell me its either one of the circut boards( there are 2) and each one will cost me from 125 to 130.00. how can I tell which circut board is bad and could there be simple problem that everyone has missed. the wash is actually a kenmore elite calypso 24082; bought in email address is
  • slmali7 Dec 20, 2008
    I have the same problem except my machine is a top load Kenmore Elite Calypso. We have checked all the connections, and my husband found a bad fuse. Now he thinks we need to get the board out to replace fuse. Could this be all that's wrong? That would definately be a great Christmas present! Sherri
  • robin Aug 15, 2013
    you can solder a new fuse on the board if it is not a replaceable one. good luck i hope it i that simple.
  • 261 Answers
On the ccu, the board on the right is usually the culprit, I have recently replaced one with that same error but I would first unplug it and remove and re connect each plug on the board looking for dark connections or dialysis, corrosion. If not fully insert each plug and try again.
Posted on Sep 07, 2008
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ... > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machine are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Kenmore Elite Calypso top loader and error code ce
Com error between control and motor. See page 51. Check for corrosion on the pins at the quick connect. Check for broken wires
Sep 16, 2011 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Calypso Model #110.24086200 SN #CR3808384 is not completing it's cycle and error code (06) shows up. What does code (06) mean?
Error codes start on page 46 and detailed instrustions to run diagnostics start on page 47.$FILE/8178010.pdf
Mar 20, 2011 | Kenmore Washing Machines
Washer won't start. shows CE on the display
That is a communication error between the control and the motor board.
Could be a corrosive buildup on the ribbon connectors and/or a bad wire or loose wire.
You can unplug the machine and trace all wires to look for a pinched or loose wire.
Unplug and clean all wire connections.
If that does not work it will be a bad motor controller.
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
649 people viewed this question
Sal De
 Brian Main
Brian Main
