Question about GE 24 in. GSD6660GSS Built-in Dishwasher
GE Triton arms don't spin
I have a 3 year old GE Triton dishwasher. The bottom and middle washer arms spin freely when I do it by hand, but when I open the door in the middle of a wash cycle they are always stationary - the very top small arm is still spinning. I've checked the alignment of the supply line for the middle arm and it is seating correctly. Help - my dishes are all dirty! =)
  • znn94x Sep 07, 2008
    Left the power off overnight, arms still not spinning.
  • 166 Answers
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
How old is the machine?
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
Posted on Sep 07, 2008
  • N Golan
    N Golan Sep 07, 2008
    Time for service and some replacement parts
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
My GE Triton XL dishwasher (6-7 years old) doesn't seem to be spraying water. Is this a fixable issue or is it time to replace it?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
Sep 06, 2010 | Dishwashers
GE Triton seems to lack pump pressure to rotate the wash arms.
1)please check the impeller nut is loose.
2) please check the hose connected to the arm any block.
Jan 08, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Maytag MDB3700AWE bottom wash arm does not move Freely by hand
Yes, the wash arm should spin freely. Recommend that you remove the arms and search for what is stopping it.
In addition to hard water, the ultra-cheap dishwasher powder really does/can leave calcium-like deposits behind. Use brand name powder for 30 days and you will see a difference. Never use gel or tablets in any dishwasher.
Adding a whole-house water softener would eliminate 90 % of your problem. The other 10% will be taken care of by not buying ultra generic powder.
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
Middle arm stopped spinning
you may be exactly right. I always start with something simple. spin the spray arm to make sure it goes all the way around with out touching anything. next is the hard partyou would have to take the motor apart and any filters you see and clean out all the debris.
Nov 27, 2008 | Dishwashers
GE Triton XL Dishwasher
Make sure wash arms are going around. Set the arms to point right at you and mark with a marker (so you can tell if the arms moved, not just turned 180 degrees) and run the unit for a few seconds. If the spray arms don't move, look for obstucted holes in the spray arm(s). Toothpicks, plastic candy wrapers, seeds, etc. If all clear, so an "Ask Me" for other ideas.
Sep 02, 2008 | Dishwashers
GE Triton Dishwasher will not drain they water after it's cycle...thoughts?
The machine was in your home 3 years , and used for more than that by someone else! I can tell you by the model that its at least 10 years old!
appliances more than 9 years old cost you money to run and fix! Throw it out and do not put good money into bad!
The new ones no matter how inexpensive will wash better and cost you a hell of a lot less to operate. They are so much more energy efficient today that they pay for them selves in a couple of years! With a new machine watch your water and power bill go down!!!
if you got the money do it new!
Bless You!
Sep 02, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Water not going through spray arms
1.does motor run? no. replace motor. door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
432 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
