Question about Nikon D70 Digital Camera with 18-50mm Lens
D70 digital camera
The compact flash card indicator light continually keeps on flashing and nothing else works on the camera even when turned on. Turn the device of and flash indicator still keeps flashing. Nothing is displayed on LED scree on top. Changed compact flash card still same problem, Any suggestions. Tried reset button but no change. Regards Roy. information@australianradar.com.au
    Problem Solver:
  • 29 Answers
Could be bent pin in the memory card slot
Posted on Jan 09, 2006
Green light on camera back to the right of the 'delete' button continually flashes on-off about 1 second intervals as soon as battery is inserted as long as CF card is in place. Switching camera ON...
I would start by looking into the memory card slot to see if you have a bent pin. You may need a small light and a magnifying glass to see them.
If the pins are okay, then you can try a reset by holding down the BKT and metering buttons together for 2 seconds. The metering button is on the left, behind the off/on/release.
Thirdly, you can try a firmware update on the camera which can be found here:
NikonTech.com
Jan 07, 2010 | Nikon D70s Digital Camera with 18-200mm...
I have a Nikon D70. Camera doesn't read CF.
Sometimes pins inside take strain.  Read up on how to replace the CF pin unit.  Not too difficult as long as you don't force anything and remember to retrieve the little metal strip....
Sep 13, 2009 | Nikon D70s Digital Camera
I have a Canon EOS 350D, Compact Flash card freezes my computer
Instead of connecting via the camera, just use a USB card reader and put the CF card in that.
Mar 17, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
May 28, 2009 | Nikon D70s Digital Camera
I have a Nikon D70 and am unable to insert memory card all the way, i double checked that it is the correct card and inserted the right direction.
STOP! You have just bent a few pins. Your camera has a male connection. Meaning it has pins sticking out. If you are unable to insert a memory card, that means a pin is bent and is not going into the holes in your memory card. This is a common problem with cameras that accept a compact flash card. This can be an easy fix or it can be a very hard fix.
Ive fixed a couple of cameras like this with a pair of tweezers. flash light (or some big source of light) and a magnifying glass. You need to look into the slot on the camera under light and look at all the pins sticking out. Look for the bent pins and use the tweezers to bend them back. Be careful not to keep bending the pin back and forth, as this will break the pin off. Ive seen cameras work without certain pins, but this is not something you want to do.
To have an SLR fixed is a minimum $160 dollars depending on where you take it too. The D70 is a good camera.
Please do not stick the memory card back in. Check the memory card to make sure all the holes are clear and have nothing blocking the holes or make sure a hole has gotten bigger and merged into one. I would use a different card once the pins are are sticking straight.
Hope this helps you.
Mar 30, 2009 | Nikon D70s Digital Camera
Nikon D70, displaying error code 'CHA' when memory card inserted. Unable to format or use memory card. Have tried new memory card, still same problem.
CHA errors indicate a communication issue with the CF card. Your card could be going bad, you could have a broken pin, or any number of other problems.
I'm running into this same problem now. If anyone has a good step-by-step to troubleshoot which of the dozen things this error could be, I'd appreciate it.
For myself, I'm planning to start by trying a new CF card.
Sep 02, 2008 | Cameras
Canon Rebel XT unable to access compact flash card
check all the pins in the CF socket in the camera are there, or are not bent, repair is expensive if broken
Jan 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
109 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
