Question about Carrier 38CKC042 Air Conditioner
Carrier central ac high efficiency
Just replaced the 250 amp fuses on the outside and the compressor will still not kick on. the fan is working on the outside and inside unit.
  • 182 Answers
Usually capacitor,burnt wires or bad compressor.kill the power and check the terminals at the compressor.they have been known to burn off if the connection is loose.
Posted on Nov 03, 2008
Why is one 30 AMP fuse pair blowing on Carrier Tech 2000 SS AC Unit?
Pull off one of the wires to the fan. If it still blows a fuse the compressor is shorted. If not replace the fan motor.
Jul 03, 2014 | Carrier Heating & Cooling
What would be the top 2 reasons 1 of the outside 20 amp fuses would blow?
There are only two possible things that it could be. The compressor or the fan motor. The compressor is self contained and cannot be serviced. You just replace the whole thing. The fan motor can be replaced.
Jul 11, 2013 | Heating & Cooling
Ac compressor makes a repetitive starting sound but wont kick in all the way. Fan is working fine.
Verify proper line voltage to the unit and compressor prior to any further testing, and correct if found below normal.
I would check the amp draw thru the compressor circuit. the compressor may very well be "locked rotor" and be pulling a high amp draw. that magic number for locked rotor amps should be listed on the compressor nomenclature plate as "lra".
the compressor may not be pulling any amps if the windings are burnt though, as their will not be any flow of power through the device.
best of luck,
ttfn
Oct 24, 2009 | Ruud Central System Air Conditioner
The compressor on my home ac willnot kick on
The fan and the compressor both run off of the same circuit. Have your husband remove the cover on the condenser coils and check for power at the leads that go to the compressor off of the latching relay. If there is power there, then he needs to check the start capacitor or possibly the thermal overload switch (mounted on side of compressor)
Jul 11, 2009 | Heating & Cooling
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Carrier central ac model 38EN036300
If you have an electronic thermostat, they can short out, leaving the compressor running. Also, the big relay that runs the compressor can get its contacts welded together. See if the contacts are stuck closed.
Jul 27, 2008 | Carrier 38CKC036 Air Conditioner
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
200 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
