Garden Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a 2000 Simplicity Landlord tractor with 54 inch mowing deck pull switch to engage deck and it will not engage, looking for answers thanks
Mark T
Level 3:
  • Master 776 Answers
  • Posted on Aug 18, 2011
Mark T
Master
Level 3:
Answers
776
Questions
0
Helped
290215
Points
2237
Tou have a broken or loose deck belt. Not an easy DIY but medium and doable. Check the belt in the deck too (the one that makes both blades spin at the same time. This belt likely needs to be changed too.
1999 simplicity landlord tractor doesn't start
Does it crank? There are a myriad of issues to check
Dead battery
Bad battery connections
Safety switches not all in right setting (like a PTO/mower deck turned on that needs to be off for starting, or a brake pedal not pressed, or a seat not sat on)
Bad solenoid
Bad fuse
Bad relay
Bad starter switch
More details can narrow it greatly. Have you tried jumping it? Do you get noise when you turn the key? Was it an all of a sudden problem, a growing intermittent one, have you tested the voltage of the battery or tried charging it? Etc.
Mar 30, 2013 • Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
I have Poulan Por 54 inch deck,25 hp Kohler hydrostatic. After I mow on unlevel ground for about 30 min. Transmission makes noise jerks and won't go till it cools off. Will changing the fluid help
couldn't hurt to try but some cheaper mowers don't have a drain plug look on a parts break down on sears parts online but check the belt tension first
Apr 13, 2012 • Garden
Need mowing belt for 54" deck
It appears there are two belts for your mower. The primary belt is JD part M143019 and secondary is M118685. Your traction drive belt is p/n M127523.
The secondary belt for a 54 inch C deck is M154960 the other belts are the same as above.
I have used these folks for replacement belts before.
http://www.mfgsupply.com/MowerBeltsJD.html
I hope this helps.
2answers
Mower starts but when you engage mower it stops
Check for a weak battery. On some lawn tractors the mowing deck is started by an electric switch, and when the deck is engaged it pulls all the remaining power from the battery thus robbing the engine of the current it needs.
9helpful
Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
1helpful
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Top Garden Experts
Jay Finke
Jay Finke
john h
