Question about Sanyo MM-8300
Hard reset for sanyo mm 8300
I upgrade to a new phone and want to reset all the data on my mm 8300. i got most of the data out but the text message "from recent list" will not clear. I will be giving this to one of my younger sons and do not want this in there. how do i delte it or hard reset my phone?
5 Suggested Answers
  • 9 Answers
SOURCE: Sanyo mm-8300
Call Sprint tech support at 1-888-211-4727 see if they can help.
Posted on Jan 30, 2008
early1234
  • 871 Answers
SOURCE: changing language on sanyo MM 8300
hi there
you can change back to default english by pressing shortcut keys.
press menu/ok
select settings
press options(right softkey)
then select language
now slect english.
hope this helps.
Posted on Feb 07, 2008
SOURCE: to unlock code no. of sanyo mm-8300
call *2 - sometimes the rep will help you over the phone and other times they will tell you to take it in to the store to have it reset.
Posted on May 15, 2008
use cdma workshop
Posted on May 26, 2008
  • 163 Answers
SOURCE: can i retrieve deleted text messages from the sim card of a sanyo scp-7050
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 26, 2008
How do i retreive deleted text messages on lg g3?
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages from Android.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Jan 01, 2015 | LG Cell Phones
I lost my text history How can I recover
Thedata recovery packis made up of two programs: Hetman Photo Recovery, Hetman Uneraser. You save up to 20% on the order price by buying the programs in a single package. The package allows you to restore important office documents, digital photos, archives, video and audio files, which have been lost by accidental deletion from your drive.Hetman Data Recovery Pack restores data from internal and external hard drives, camera and mobile phone memory cards, and USB memory sticks. Instant data recovery software recover all your deleted or logically damaged data from FAT and NTFS volumes.
You can download the data recovery pack to assess its ability to restore your required data. Data from recovered files found following a hard disk scan is guaranteed to be restored, once you purchase the program.
Key Features:
· Restoration of information from internal hard disks and external IDE / ATA / SATA / SCSI disks and logical partitions, and restoration of USB storage media;
· Restoration of data deleted from memory cards for digital cameras, mobile phones, smartphones and PDAs;
· Restoration of files lost following formatting of logical partitions FAT and NTFS (supports NTFS compression);
· Restoration of data accidentally deleted from USB memory sticks (including manufacturers Jetflash, Apacer and Sony).
May 26, 2013 | Motorola Cell Phones
Sanyo 8300
First, you need to remove the battery and any flash cards, then you need to dry the phone (NOT WITH A HAIRDRIER!). To dry the phone, you should bury it in a bowl full of those moisture-absorbant "do not eat" packs that come with shoes or other purchases. However, these are often not available. Instead, use plain white rice (dry) to bury your phone in a bowl. Leave it for 1-2 weeks (the longer the better, up to a month) and one last thing, if it was removed from soapy water, as odd as it sounds, it should be fully rinsed in clean cold tap water. If it still won't work after all that, you could try a data-retrival place (if you can pay for it!). Hope this helps, WolfIan.
Apr 30, 2008 | Sanyo MM-8300
Sanyo MM-8300: ALL the keypads are frozen and won't work. Any solutions?
One thing you could test for is a thermal-fault in the phone's circuitry. To do this, you put your phone in the fridge over-night then, turn it on the next day and try the keypads while it's still cold from the fridge. If that doesn't help and you're brave enough to venture into the inner-workings of your phone to attempt repair/cleaning, you can read my post here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Apr 20, 2008 | Sanyo MM-8300
To unlock code no. of sanyo mm-8300
Mar 14, 2008 | Sanyo MM-8300
Keys won't work on sanyo mm 8300 phone
I used a very small eyeglasses-repair flat-bladed screw-driver that was the same width as one side of the tri-angle screw head to remove the screws on half of a sanyo scp-8300 phone that I found on the road. I do advise caution when releasing the hidden plastic clips around the edge of the phone where the seam between top and bottom is. Once open, you will find a ribbon-cable that leads to the top half of the phone, a rubber pad that has all the keys on it, and the phone's circuit-board, where there is a white plastic sheet overlaying the actual physical buttons mounted on the circuit-board. My advice would be to gently clean the rubber key-pad with warm water and dish-soap. Also, check for sticky gunk around the edges of the key-holes in the plastic case of the phone, if you find some- carefully wash it off with a wet tissue or a cotton swab, use rubbing alchohol if it won't clean off. But, be aware that some plastic can melt or turn gooey when cleaned with alchohol, or it might just remove the color from it. Hope this helps, TechnoWolfy.
Feb 12, 2008 | Sanyo MM-8300
Changing language on sanyo MM 8300
hi there
press menu/ok
select settings
now slect english.
hope this helps.
Feb 07, 2008 | Sanyo MM-8300
Keys will not work
Sounds like you locked the keypad.
I know you stated all the keys don't work, but let's give this a try.
Press the "unlock" key (the key in the upper left)
Enter your lock code (usually 0000)
Let me know if this helps.
Jan 11, 2008 | Sanyo MM-8300
Sanyo SCP-8300
I'd suggest a new battery, if money is no problem but otherwise, if you have a volt-meter of some kind, you could read the voltage output of the charger and compare that to what it says it should be in the input-output list usually printed on the underside. If it's fine, I'd try carefully cleaning the phone's battery and charger contacts with a small amount of rubbing alchohol and some cotton swabs or tooth-picks lightly wrapped in toilet or tissue paper. If it still refuses to work, you could see if a sales-clerk at your local phone store would let you try a new battery to see if it would work. Otherwise, you could attempt internal repair/cleaning like I outlined here- keys won't work on sanyo mm 8300 phone.
Oct 09, 2007 | Sanyo MM-8300
Need help unlocking my phone from Qwest so I can use with Alltel...
Some local wireless stores can do this for a small fee. Try finding a wireless supply store and see if they offer this. Most phone companies won't do it because they want you to stay on their network, and/or they want you to buy their phones.
May 29, 2007 | Sanyo MM-8300
Cell Phones Logo
831 people viewed this question
Top Sanyo Cell Phones Experts
rey francis basa
rey francis basa
Vorked Entertainment...
Ben Darden
Ben Darden
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
