Question about Sangean America HD Radio Component Tuner
No alpha numerics
My Sangean HDT-1 HD receiver shows no alpha numeric info, only a blue
back light lights up. This is the second receiver I've had that has done this.
Is this a common problem? I hate to give up using it for the sensitivity and
the selectivity. And I have an antenna and rotor that I would hate not to be
able to use. Any info you provide will be greatly appreciated. Thanks.
................David Nordmann.........(djnordmann@sbcglobal.net).
PS--Second replacement only worked for 4 days.
    Problem Solver:
  • 8 Answers
Hi David, I can't seem to find that this is a common problem (at least not yet). Hopefully the unit is still under some sort of warranty. I might suggest looking for a model hdt-1X that has the .4 version of firmware. Apparently with the .3 version the display is never turned off (even when the unit is in the "off" mode). With the .4 version you can dim the display and it will turn off when the unit is in standby mode. For other differences see this link: http://www.ham-radio.com/k6sti/hdt-1x.htm Sorry I don't have any better solution for you at this time but I will keep a watch out and post any further findings. Happy Trails ...... Jack
Posted on Sep 09, 2008
Where is serial number for Samsung hd tv 4003
Should be on the back of the flat screen.
Dec 25, 2014 | Samsung UN32D4003 32 LCD TV
What is alpha numeric
Alphanumeric (sometimes shortened to alphameric) is a combination of alphabetic and numeric characters,
For example, An Alphanumber word would be Today1234. It contains letters and numbers.
May 01, 2014 | Cell Phones
'tab' button doesn't work on Motorola MC3190
You get 3 different keypad models of the Motorola MC3190:
- 28 Key Numeric
- 38 Key Shifted Alpha
- 48 Key Alpha Numeric
So depending on the type of keyboard your model has, using TAB are different across these 3 keypads.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
When the FUNC button is pressed the icon "F" appears on the taskbar on WinCE devices or the icon "Blue Circle" appears at the bottom of the screen on Windows Mobile 6.1 devices.
In order to use the TAB function, do the following:
28 Key Numeric - Press the blue FUNC button (Bottom right next to Power button), and press the RIGHT ARROW button.
38 Key Shifted Alpha - Press the blue FUNC button (Right side below RIGHT ARROW button), and press the RIGHT ARROW button.
48 Key Alpha Numeric - Press the blue FUNC button (Right side below ENTER button) and press the number 9 button.
Apr 18, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Remote will not respond. New batteries installed. I can change channels at receiver, but the remote will not do anything, even though all the led's on the remote will show lite when pushed. 6.4 ir/uhf...
Is the remote for TV 1 or TV 2. If it is for TV 2, the blue tab with the number 2 should already be on the bottom of the remote. If it's for TV 1, you need to remove the blue tab from the bottom of the remote and flip the tab over (should be a green tab with only a green 1 on it). Once you change the tab, see if you can change channels. If you can't, follow the instructions below.
At your TV 1 location on your receiver, press the System Info button to display the System Info on your TV. At the bottom of the screen, you should see Primary and Secondary Remote Addresses. Make a note of the remote addresses. With the new remote, press the record button. If this is the TV 2 remote (blue tab on the bottom), the secondary number may change; if TV 1 remote (green tab on the bottom), the primary address should change. Exit from all the menus on the TV screen till you are back to your TV picture - then try the remote.
If the above steps do not work, try the instructions below to manually program the remote to the receiver.
  • Remote to the receiver:
    1. Go to System Info screen.
    2. Hold down the SAT button until all mode lights light up.
    3. Enter a number between 1 and 15 using the numeric keypad on the remote.
    4. Press the pound (#) button.
    5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Aug 16, 2011 | DISH Network IR Remote Control
After uploading all my musci on to my mp3 player when i go to play my music and the albums without track names that are just named track 1, track 2, track 3, and so on are out of order because they are...
You can copy these tracks back onto your computer, delete them off your MP3 player.
Rename each track to the song name and then copy them back onto the MP3 player
Apr 09, 2011 | Coby MP620 MP3 Player
Dish Network IR Remote's SAT Mode Not Working ________________________________________ I programmed my Dish Network Remote (IR 1.5 Blue Button Remote Control ) for my Sharp 27F543 and now the remote would...
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
  1. Go to System Info screen (in this case -- obtain by removing smartcard from receiver)
Hope this helps!
Jan 01, 2011 | DISH Network IR Remote Control
Secondary remote to other receiver is controling second tv on primary receiver
mirvin930,
Any time a different remote is controlling a different receiver, changing one of the remote addresses on should remedy the situation. I have provided instructions on changing the remote address.
Ray Calo
DISH Network - Executive Offices
  • Remote: All Other Remotes
    1. Go to System Info screen(Press MENU button twice or press MENU and 6,1,3 on the number pad on remote)
    5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Jun 07, 2010 | DISH Network 721 DVR Remote Control
Keys that have Alpha and Numeric always show numeric and not alph
Try replacing the keyboard. sounds like a button is stuck and is causing the problem.
Jun 03, 2010 | IBM ThinkPad T41 Notebook
My remote control 2 stopped working?
duncanele24
Have you replaced the batteries in the remote? If so, then I have provided instructions on how to readdress the remote to the receiver. If this doesn't work, then unplug the receiver from the electrical outlet for about 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire satellite signal. I hope this helps.
Ray Calo
DISH Network
Apr 24, 2010 | DISH Network IR Remote Control
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
Sangean America HD Radio Component Tuner Logo
110 people viewed this question
Top Sangean Audio Players & Recorders Experts
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
