Question about NetGear WGR614 Wireless Router
Can the wgr614 v6 connect to another wireless network wirelessly? I want to extend the range of my wireless network.
    Scholar:
  • 89 Answers
No. it cannot bounce off signal to extend its range
Posted on Aug 18, 2011
SOURCE:
I want to hardwire a range extender to my wireless router.
You could use wireless routers as an extender if you don't mind the hassel of configuring it.
Dec 15, 2013 | Computers & Internet
Belkin f9k1106v1 range extender not connecting
Hi , I was also facing same problems.I have solutions please follow some steps:
1.Restart Your Main Wireless Router And Modem.
2.Now Turn Off Your Belkin Range Extender And Wait For 20 seconds (unplug From Power)
3.Please Plug Your Extender Back To Power Outlet And Restart Your Computer.
Still Having Problems?
Don't Worry Visit here for more solutions:
Belkin Range Extender Won Connect to Wireless Router TechVaidya
Dec 13, 2012 | NetGear Computers & Internet
I have two netgear routers wgr614v7 and wgr614v10. how can i use one of the as a repeater?? wgr614v7 does not have wireless repeating function..
Most routers (Wireless-G) have about the same range. However, the actual range in real-time environment is much less. I think that your network would work fine if you place the router at a suitable location i.e. at the central location/ height. Also, based on my on-site experience, I suggest that you may relocate the router to another location depending upon your network environment. It has always helped me a great deal. Placing the router avoiding obstacles such as concrete pillars, walls, steel cabinets etc in the signal path have remarkable effect on range and overall performance of the network.
2. There are two ways to increase the range/ coverage area (i) Adding external antenna of appropriate type (ii) Installing additional Access Point (AP) connecting it with the existing AP wirelessly in line-of-sight (creating WDS) OR connecting the two APs with wire, which is a better option as it provides robust and reliable connectivity between APs.
3. So, in short, to extend the range, it is recommended that you may place the additional router at an appropriate location as described above and connect it to the existing router through wire (CAT-6 Cable). (The router would communicate through wire and the range of your networ would extended up to the placement/ location of the additional router. Rename the additional access point for easy identification and make it secure.
Hope it helps! Good Luck!
CreativeTECH
Feb 28, 2011 | NetGear WGR614 Wireless Router
Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
The range expander helps to extend the range of wireless network...
Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
Site survey searches for the available wireless networks in range...
It should show your existing wireless network...
You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
Thats it...
You are done...
Your wireless network range would have extended now....
Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
My netgear wgr614 is not working. I have no
To establish a wireless connection between the router and computer, the router’s wireless setting (SSID or Network Name, Channel, and Mode of communication) has to be configured. Please follow the steps below to configure the wireless settings on your NETGEAR router.
  1. Connect a computer to the LAN port of the router using an ethernet cable.
  2. Open up a browser and type in the following URL: http://192.168.0.1 or http://192.168.1.1 (depending on the model number of the router)
  3. Type the Username as admin, and Password as password. Then click OK.
    1. To change the Wireless settings, click Wireless Settings under Setup on the left menu bar.
  1. Under Wireless Network, (make a note of these settings, you need these values to configure your wireless clients)
2.
    • Change SSID from default NETGEAR to any desired name (for e.g. Home)
    • Select the Region as applicable - Incorrect selection may cause performance problems.
    • Select any one of the available Channel.
    • Apply the changes
Configuring Wireless Clients:
The steps explained below use the Windows XP wireless client. If your card came with
its own wireless configuration utility, you may use that as well.
  1. Open the Control Panel from the Start Menu.
  1. Right-click Wireless Network Connection and choose Properties.
  1. on the Wireless Networks tab and if unchecked, check the box for Use Windows to configure my wireless network settings.
Then click OK.
  1. Right-click on Wireless Network Connection, Select View Available Wireless Networks
  1. This will lists all the available wireless networks in range. Select your network from the list and click Connect.
If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key (if you are using WEP security, make sure you are typing the network key, not the Passphrase) and click Connect
  1. Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wirelessly.
May 18, 2009 | NetGear WGR614 Wireless Router
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
Compatibility with Sitecom wl 031
This 10dBi omni directional antenna enables you to very easily extend the range of your wireless network. By linking the Omni Antenna to your wireless router, you gain the benefits of an optimum wireless signal while minimising the number of ‘dead spots’ (points in your home where the signal is either weak or lost).
However it does not fit the following types of routers,modems and accespoints:
WL-143
WL-122v2
WL-114/WL-517
WL-114v2
WL-108/WL109
WL-111
WL-106
WL-025
WL-018v2
These antenne's will also fit other brands of wireless products that use an SMA connector
Jan 29, 2008 | NetGear WGR614 Wireless Router
WRT54GS V6
leave the wireless router settings unsecured then place the range expander as near as possible to the router. press autoconfig buttons and observe the lights...
Jan 12, 2008 | Linksys Wireless-G WRT54GS Router...
NetGear WGR614 Wireless Router Logo
94 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
