Question about Orion VR213 VHS VCR
VCR picture won't work
I have audio but no video when I play a tape that has been taped. I have used a head cleaner, but it didn't help.
I have found that just cleaning the head with the tape cleaner (the wet one works best) I have to clean it at least 4 or 5 times in a row sometimes before the picture will come back on. I bet that'll work for you.
Posted on Sep 27, 2008
Why is there an audio playback glitch?
Old or worn Audio Tape Head needs replacing,
Head Cleaning tapes are not the best for these, they can only be used so many times and they do rub tape carbon into the tape head, best thing to do is get an ear bud cleaner -"Cotton Buds" - and dip it into metho and give the tape head a light rub with it and ear bud, should do it...if still has issue then the tape audio head is had it, but rarely do they breakdown.
Apr 25, 2017 | Canon ZR300 Mini DV Digital Camcorder
I recently purchased this from a pawn shop. I tried playing back a few of my old tapes and the video and audio is choppy. Is it the camcorder, settings or tapes?
It is possible that the camcorder was off use and resulted in drop of values in the servo sections. First of all open the tape door section and do a good cleaning of the audio/control head . See if any dirt had accumulatted onthe heads, be verry careful to clean or use a good quality cleaning tape. Check and see if your old tapes are tight , rewind and forward before playing stored tapes. If this wont solve the choppy playing, thenit is possible that the servo section of the camcorder needs attention. Get help if not familiar as it needs experience to open and probe, but this can also be very expensive. Hope you try the cleaning first. Good day
Aug 06, 2010 | Sony Handycam DCR-TRV103 Digital Camcorder
I was trying to view so vcr tapes I had video some years ago and I loaded a tape and started watching it and all of a sudden the picture went out but I could still hear. I used a head cleaner and the tape...
yes, this is what happens to analog tape...it gets corroded because it was not stored in a cool spot...your vcr heads are cleaned that is why u still hear the audio...(video will go first all the time)...but if you play it all the way through once a twice (see if you can save it ...dvd)
Jun 27, 2010 | Televison & Video
Static but no pic , only audio
The tape you were watching was probably worn and left a little of its oxide surface on the VCR's heads. This is pretty common, especially if you ever play rented tapes or tapes that have been around for a while. Plays great, then the next time, no picture.
A head cleaning cassette may solve the problem for you. Make sure you get a wet-type cleaner. Radio Shack has one on their website, and you can probably find one locally. If the VCR hasn't recently (or ever) had a good professional cleaning, it might be time for one. The whole tape path (everything the tape touches, and not just the heads) need to be cleaned and a cleaner tape can't do that. Video rental shops used to offer cleanings. Maybe one in your area still does or there's a shop you can take it to. We charged $20 some years back when I worked at a shop. Today it might be cheaper to replace the VCR than to clean it.
Apr 22, 2009 | Toshiba SD-V295
VCR sound works but no picture
It could be that the video heads are just clogged.
Get a known good video tape and put it in the unit and let it just play and play and play. Quality video tapes have head cleaning substances built into the tape. If this does not work, get a Scotch Black Watch tape head cleaner. If that does not work the the heads are bad or some other problem.
Jan 07, 2009 | Zenith ZHX-313 System
Audio works but no picture
simple clean head with Q tips by hand use the head cleaner on Qtips clean good dont brack the tip on head .good luk
Dec 26, 2007 | Sanyo VWM-950 VHS VCR
NEC VH-605 VCR - Very Snowy Picture
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
Sep 01, 2017 | NEC Audio Players & Recorders
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Unable to record or playback VCR tapes
All you can do by yourself unlesss you are a tech. Is run a head cleaner tape through it. It sound like a dirty head to me. Here is something a lot of people do not know, The video head and the audio head in a VCR are two separate heads. thats why you can loose picture and not sound. Best taken apart and cleaned manually with rubbing alchol but not advisable if you are not experienced due to high voltage and if cleaning improperly you can damage the unit worse. Good Luck
Nov 25, 2006 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Philips vr630 vhs
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
Jul 14, 2006 | Philips VR630 VHS VCR
Orion VR213 VHS VCR Logo
87 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
