Question about Marantz Audio Players & Recorders
My receiver sr7001 will not turn on. The stand by led flashes and that is all the receiver will do. Is there any ways of resetting or changing interior fuses. I have only found 1 fuse and it is not blown.
    Problem Solver:
  • 5 Answers
Check ALL the switches to select inputs, speakers, AM-FM, ect,ect.....I purchased an Onkyo 5.1 Receiver Amp that retails for $500 to $600 for $9.00 at Good Will. Nothing worked when I applied power to it. So I checked all the switches. On was stuck in the down position. So I lifted it up and after powering it down and up it started to work. Can't beat the cost. Try this on your receiver. Apparently logics freeze up, like a switch will make it look like when you tried to power up. Good luck. David N
Posted on Sep 06, 2008
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
60" sharp aquos power indicator is flashing one short flash and one long flash and keeps repeating the sequence
1)Plug in TV to electric current First then wait until LED start flashing.
2)Press Volume DOWN [ - ] HOLD BUTTON.
3)Press Channel UP [ ^ ] HOLD BUTTON.
4)Press Power [ (') ] HOLD ALL three buttons until LED stops flashing and then release.
    ·This will reset the TV in order to fix the problem.
    ·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's.
    Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one!
    Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to LGTR61@YAHOO.ES. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions.
    Where can you buy the LED's - try searching or for resellers.
    LONG STRIP (49 LED's)
    SHORT STRIP (30 LED's)
    RL 94v-0
    1025 LFa
Apr 10, 2013 | Sharp LC60LE810UN 60 in. LCD TV
My marantz sr7001 has sound but the video wont show on the tv
Video processing section circuit should be troubleshooted. Seek tech support.
Jun 03, 2012 | Marantz SR7001
Power protection shutdown
check if the speakers are the right ones for him
May 20, 2012 | Marantz SR7001
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Dell Wireless Mouse - new batteries - red light flashing - mouse on screen will not move. Have re-booted several times to try and clear problem with no results. Mouse on screen frozen
There should be a wireless receiver to plug into your USB port. THis has an LED on it which will flash when it receives data from the mouse. If the LED is not flashing then it is not receiving. There may be a button on the mouse to reset or change the transmission channel. Try unplugging the USB receiver and plugging it into a different USB port.
Feb 18, 2011 | Computers & Internet
Forgot password and username
Yes there is.
These steps came from the MSI website itself. link
Restore with reset button
1. First turn the power off the router and press the "reset" button.
2. Power on the router and hold the reset button until M1 & M2 LED or Status start flashing.
3. Release the reset button. If the LED flashes eight times that means the reset is done but if the LED light flashes twice you need to repeat the steps.
Reset the router while the power is on.
1. Press and hold the reset button for about 5 seconds M1 should flash 5 times, release the reset button and the restore/reset process is done.
Nov 24, 2008 | MSI Wireless-G RG54G3 Router
Nad 712 output issues - Mute flashing
The only thing I can tell you for sure is that the mute indicator always flashes (very dimly) when the receiver is off.  I have no idea why, but mine has always done this.
Jan 23, 2007 | NAD 712
232 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
