Question about Hitachi Televison & Video
Picture started out with about a 1 to 2" black streak on each side of the picture. The tv is a 36" pc ready color tv model 36sdxo1s. The black streak on each side of the picture is getting larger.
  • 4 more comments
  • rndvm Sep 06, 2008
    This is not a projection tv.
    I repeat this is not a projection tv. Need assistance for this model.
    this is not a projection type tv.
    I was asked to post the model number which is 36SDX01S. PC ready color tv
    This is a 36" Hitachi PC Ready color tv. 36SDX01 is the model number.
    When the tv is first turned on the picture is very narrow, it eventuallyl widens out with about 3 to 4" on each side. The picture is clear but getting smaller from each side.
  • Hitachi Master
  • 19,396 Answers
Try unplugging TV for ten minutes first.
Posted on Sep 06, 2008
  • 4 more comments
  • Ginko
    Ginko Sep 06, 2008
    Try unplugging TV for ten minutes first. Then ensure it is not a setting problem with Image setting at 4:3.
    If the two bands are kind of moving and the picture is getting slimmer all the time , then is a convergence problem, one of the convergence ICs has blown and must be replaced.
    A technician will take apart the back of the TV, test the faulty STK ic on the convergence board inside the TV and replace it.
    After this a convergence setup procedure must be performed.
    If you need to call a repairman you can use the number listed on the owner manual.
  • Ginko
    Ginko Sep 06, 2008
    What kind of TV is then, you posted on projection TVs, is it CRT, plasma, LCD, rear projection or projection/LCD technology.
    On LDP and crt it is probably a convergence IC problems.
    Post the model for more information.
  • Ginko
    Ginko Sep 06, 2008
    if you don't tell me the model we go nowere, 36sdxo1s is not a valid model number, post make and model correctly.
  • Ginko
    Ginko Sep 06, 2008
    Well it is a progressive scan tv, it has convergence board controlled by two STK ICs the same as a CRT and a Projection I think.
    In any case start going to the video settings menu and do a reset check page 33 of user manual here .
  • Ginko
    Ginko Sep 06, 2008
    If you are using the TV connected to a computer, see also PC mode control to set display width at page63
  • Ginko
    Ginko Sep 06, 2008
    Try doing the reset suggested above, see if they work, leave also the TV unplugged for few hours tonight.
    Generally, if the bands appear only for some times , then image expands regularly it is a faulty IC or capacitor, that works fine only after it warms up.
    I work on PC monitors etc.I have not serviced your model yet, and I don't have the service manual to follow the troubleshooting diagrams to locate faulty area on the board, test parts and find defective one.
    If you want to DIY here is the service manual.
    Here you get all parts for your TV.
    If you want to call a technician there is a number listed at the end of the user manual.
    If I find any free schematics I will post here.
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Hi, I try to connect my PS2 to LCD TV and its has no color. The TV is LG and I tried the with SCART and with those holes on the side of TV (yelow, red and white). The strange is that when I start the...
make sure to set input on the TV is set to s-video.
If left on AV2 the picture is black & white.
Set to AV2S the picture is in colour.
http://www.avforums.com/forums/ps2/692572-ps2-picture-black-white.html
here some troubleshooting steps to help find out what maybe wrong
1. try a different tv 2. if you have a friend with a ps2 try borrowing their cable to make sure its not the cable. 3. try your friends ps2 on your tv.
Jun 01, 2011 | Video Game Consoles & Games
My t.v. whines when innitially plugged in. no picture (rca f36650) guide plus gemstar xbox ready entertainment series
The tv have a dead part call the FBT-Flyback transformer,a big black block of plastice with a red wire with a black cap hook it to the CRT-(Tv picture tube).The FBT-give the tv highvoltages to the CRT(Tv picture tube).This tv is old model of an analog tv probally can't find part for it anymore.
Dec 08, 2010 | RCA F36650 36" TV
Our Sony TV started to display something that looked like interference, with sharp horizontal white streaks across the screen, accompanied by loud popping noises. It has nothing to do with the cable,...
According to the symptom the FBT Which is called "Fly Back" is popped, and it needs replacement. Details like Part No. and Description is given below:
145334611 FBT ASSY (NX-6000//J1J4)
Replace the FBT and your tv work fine again.
Nov 18, 2009 | Sony KV-36XBR450 36" TV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
36 in toshiba
please model would want would say in a television toshiba to me cf2048, as I can abrir a little the vertical one because it has black strips in both sides as of centimetre of width, thanks, Gerald
May 17, 2008 | Toshiba 36A40 36" TV
Color vs. Black/White picture issues
If the trouble is black and white looseboard in CRYSTAL. Loose need to resolder.
Apr 16, 2008 | Toshiba CF36G40 36" TV
Black border
u are have a horizontal problem. seek pros help
Dec 25, 2006 | Panasonic CT-36G34 36" TV
Televison & Video Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
