Question about Sony Cyber-shot DSC-S600 Digital Camera
Power button stuck
Hi i have the same problem the power button is stuck i ahve tacken it apart but dont know how to get to to power button to have a look can some one help me out regards stephen
  • 2 more comments
  • Darrel Cure Sep 14, 2008
    i have the same problem. I put new batteries in and when i press the power button the screen says "sony cyber shot" and then it just shuts off on it's own.
  • bstephen62 Sep 25, 2008
    http://www.eserviceinfo.com/equipment_mf... hi all if you click on this link you can download the service manuals for sony cybershot dsc s600
  • dicosme69 Feb 07, 2009
    I also have the problem that the power button is stuck. The button is stuck inside the camera. I cannot use my camera. I need an easy solution. Or should I just buy a new one?
  • manda_ched Apr 03, 2009
    My Cyber-shot DSC-S600 Digital Camera power button is not working. My husband opened the camera and saw that the wire was damaged and he felt the repair described by Guest would not suffice.
    I am fond of this camera, it was a wedding present, can anyone think of where I can take it for a cost effective repair or how I could do the repair with step by step instructions.
    Thanks Manda
The power button is nothing more than a molded piece of nylon that can break. It's an easy fix if you feel like taking the camera apart which is quite simple. It is rather intuitive and one can figure it out as you break it down. The piece can be repaired by buying a thin 5 cent nylon washer at the hard ware store and gluing a new piece onto the broken piece with epoxy. You'll notice a little "bump" on the bottom of the piece which will make contact with the shutter. You can build a small piece of nylon washer onto it in the exact same place. Reverse the breakdown to assemble it and presto!!... a repair for 5 cents!!! Google "how to disassemble a sony dsc s600". Beware...the capacitor can hold up to 300 volts and can bite you. Hope this helps.
Posted on Sep 23, 2008
Hi i have a nordmende tv and was working until it was plugged out of the mains now it stuck on standby and i dont have remote its an nw32lqt any ideas for easy fix i ve tried letting capicators drain no...
while the TV is on standby, press the channel + or channel - button on the TV and the TV should power on.
If TV doesn't power on after pressing the channel button, then it means your TV is having a power problem. But I don't what to believe it is a power problem.
Let me know if press the channel button does not power on the TV so that I can explain further on the cause and way to fix the problem.
Yours sincerely.
Elect_Comp.
May 16, 2011 | Televison & Video
Have tacken it apart and the power bord is blown where can i cet a now one for it can any one help
I use shopjimmy alot and have had very good luck with their boards. I found it there but its currently out of stock.
I would call them on Monday and see when they might get some in.
Heres the link to the board on their website
http://www.shopjimmy.com/powerspec-6693006610-power-supply-unit.htm
The part number is 6693006610, I also checked on ebay and found pretty much every part for your tv but the power supply.. You can search there using the tv model number and companies are always adding parts there as they get them..
I had no success with any of my parts vendors that carry replacement television parts. None of them carried Tatung..
Shopjimmy is going to be your best bet..
Good Luck!!!
Dec 04, 2010 | Tatung V30DMTT 29.6 in. LCD Television
IPhone 3g does not work!
Hold in the home button and power button until the apple comes up!!
Jan 12, 2010 | Apple iPhone 3G
Brother Personal FAX 275 keypad problem
the button might be a little sticky if you get a little bit of glass cleaner spray it by the button and let it sit for a minute the keep pressing teh button lightly a few times it should clear out any gunk on teh button failing that if you know how to take the cover off you can clean it that way .. if it still sticks try swapping it for a button you dont use you will ahve to take the button off by desoldering it and swapping
Sep 29, 2009 | Brother Personal FAX-275 Roll paper...
Cd stuck in cd changer
You could take the radio out and take it apart, but you would still have an $1800 CD. Suggest forgetting about the CD, and getting an aftermarket installed for much less.
Mar 07, 2009 | 2005 Suzuki Aerio SX
Sansa E200R gets stuck in refresh when I turn it on
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Sencer button
take the phone to a mobile center and ahve them fit it for you
Jun 24, 2008 | Sony Ericsson K800i Cellular Phone
DVD drawer stuck out
Try to unplug the unit from its power source, give it a minute then plug it back in.If open appears on the window, hit the eject button. See if that will work for you. If that dont work, hit source and on at the same time, then eject if open appears in the window. That should close the draw for you.
Apr 19, 2008 | Bose 3·2·1 II System
Cant connect to wifi?
Hi how are you. what kind of wireless card is it? what operating system are you running? andwhat kinda router do you ahve in your home an what inda internet connection do you ahve cable modem? dsl? i may be able to help you with this. did you also install th drivers for the wireless card properly let me know I can help you
Oct 01, 2007 | Toshiba Satellite M35X-S111 Notebook
Sony Cyber-shot DSC-S600 Digital Camera Logo
204 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
