Question about Smeg Washing Machines
Error code e06 smeg washing machine wdi/12c - Smeg Washing Machines
SOURCE: error code e14
E14 Dryer temperature probe in short circuit or interrupted
Posted on May 10, 2008
eagle338
  • 4889 Answers
SOURCE: Smeg WD1 12C, error code 10
Dryer temperature sensor (NTC thermistor) is faulty - short or out of circuit. You will need to get a tech to fix it for you.. It is not user servicable..
Posted on Nov 06, 2008
  • 8 Answers
SOURCE: smeg wm16aaa error code e06
HEre's a link to Smeg's web site with all the error codes:
http://www.smeg-service.co.uk/support/index.php?a=1#1
The only problem is that the code doesn't really tell you a lot though apart from it's probably not draining properly. Does any one have any ideas for E06?
G
Posted on Dec 08, 2008
SOURCE: Hi, I have a Siemens washer dryer model WDI 1442.
any luck - i have the same problem
Posted on May 31, 2010
rickead1
  • 1998 Answers
SOURCE: we have a Neff washing
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced but first check to assure that nothing is stuck inside the pump or one of the lines goiing to the pump they are not expensive if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Posted on Dec 10, 2010
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
I have a smeg washer drier wdi 146 with error code e13. Can you tell me what the problem might be. Thanks
i beleve your door interlock is fautly
or the wiring too it can overheat and cook
so youll need a new one from smeg uk
and check out the connector for any issues
see here for some details
although its a different model i would assume the company uses the same error code setup for all its models
and i would order direct from smeg
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/error-code-e13-smeg-wdi12c6-washer-dryer-t75513.html
Dec 20, 2014 | Washing Machines
Washing machine not draining the water
the weater pump is bad replace....
Apr 13, 2010 | Neff W5340X0 Washer
Smeg wm16aaa error code e06 Can anybody help me on the above please
G
Nov 08, 2008 | Smeg WM16AAA Front Load Washer
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
Loud noise coming from machine
i would say its the bearings in the drum rather then the motor,that would be expensive over $200?
Dec 19, 2007 | Smeg WDI12 Front Load Washer / Dryer
WDI12C Machine Will Not Drain - Error Code E06
remove the two wires from pump connect two wires with a test bulb. this would eliminate the control issue if the bulb lights. 240 volt bulb. take it from there
Nov 24, 2007 | Smeg WDI12 Front Load Washer / Dryer
Error code e14
Jan 29, 2007 | Smeg WDI12 Front Load Washer / Dryer
Washing Machines Logo
178 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
myrlanthian
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
