Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Oven Door Hinge Squeaks
The oven door hinge on the right side just started squeaking a little while ago, what can I use to lubricate it? The oven is in use about 4 years now and it is level.
  • 2 more comments
  • Anonymous Nov 05, 2008
    I have a very squeaky oven door. It sound slike the door opening of a haunted house horror movie. Really noisy, but only when the oven temperature is on.
  • Anonymous Dec 24, 2008
    Mine sounds like a castle moat door! Jenn-air has been a real disapointment from the beginning. The spark wouldn't stop firing after ingition so service fixed it twice under warranty then it went again three days after it expired and they wanted to charge me to fix a problem that was never fixed in the first place. got them to cover it.
    Now the gut wrenching squeak!!
    Next time I'll check Consumer Reports before buying. Never again Jenn-Air if your listening. Tell all your friends.
    Merry Christmas- at least until the oven door opens.
  • htimm Apr 11, 2009
    Did you ever cure your oven door squeaks? I have the same problem--just oiled and greased it but no luck so far.
  • m1mike May 01, 2009
    Electric stove's bottom storage drawer has terrible scrapping noise when I open and close it. Afraid to use petroleum products for obvious reasons. Any help would be appreciated.
  • 2,920 Answers
Try wd-40
Posted on Sep 06, 2008
2 Suggested Answers
  • 640 Answers
SOURCE: Oven Door Hinge Squeaks
its not the hinge,,its the sping in the hinge,,you have to replace it,,,be careful with ludes on stove...onthejob
Posted on Jan 19, 2009
Door came off. Can it be repaired?
perhaps someone that welds could fix it . should have done something a year ago
Jun 11, 2015 | Panasonic NN-SD797S Microwave Oven
Squeaky door
Buy a spray can of silicone lubrication and spay the hinges wipe off any over spray rotate the door 3 -4 times also clean door seals thoroughly, repeat if necessary.
Mar 10, 2014 | Maytag MSD2756G Side by Side Refrigerator
Door Make Noise When Open and Closing.
If it is a squeak, you can lubricate the door hinges. If it is some other noise you will need to describe it.
Aug 18, 2011 | Frigidaire FRS3R5EMB Side by Side...
Squeaky Door
Open the door and look at the bottom hinge. There is a plastic piece between the door and the hinge, this is called a cam, it helps keep the door in different positions. The cam should not move when the door moves, if it does you should be able to tighten the screw holding it on. If it does not move then a little lubricant on that cam should help.
Apr 18, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Garage door squeak when closing
I had a similar problem and tried simlar fixes. Spraying the chain, the rollers, the track with silicon based lubricant did not good for my problem. My wife then listened carefully from where the squeak was coming. It was coming from the hinged in the actual door, the hinge like parts that allow the door to roll up. After we sprayed all of them, the sound just went back to the normal electrical / mechanical sound of the door opening and closing. I am sure our neighbors are happy too after 6 months of (very) early openings. Hope this helps.
Mar 21, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Under counter dishwasher door "squeaks".
The door hinges will have to be replaced. They have been updated to prevent this. Read about it here and good luck.
btw I have used Vaseline applied to the cables to eliminate this issue.
Feb 25, 2009 | Kenmore 46462 Front Load Washer
Dec 20, 2008 | Magic Chef 31000 Gas Kitchen Range
Viking Ultraline Professional Gas stove
It is visible the hinges /w40 has extension nozzle spray the hinges a few minutes open slowly/ by moving little by little until the lubricant or oil penetrate the moving parts of hinges ,
Jan 01, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
May 16, 2007 | KitchenAid 24 in. KUDS01FLBL Built-in...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
3,401 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
