Question about Panasonic AJ-D230H DV/Mini DV VCR
Carriage won't drop
The carriage moved to the rear but then locked up and won't drop. I have turned the unit off and on...and I can hear a couple of "clicks" when it powers up but the carraige won't move. I have even taken off the cover and depressed the elevator gear - if that's what it is called, the little red topped gear on the left toward the front. Still, the carriage is stuck. Any ideas? Thanks
  • OlTVGuy Mar 26, 2008
    A student tried to put the wrong video tape in the machine. I was jammed. I was able to get the gears back into the right position. Now, the video tape lifter or carrage will not lock back up so you can put a tape in properly. I am trying to find what holds the carrage up with out falling back down into the machine without a tape loaded.
    Champion:
  • 221 Answers
The carriage in the AJ-D230 and AJ-D250 has two gears on the sides that operate two arms that raise and lower the carriage. These gears are a two-piece construction, with a circular metal spring providing tension between the two pieces. Over time, the plastic tabs that hold the spring deteriorate and break, and the gears no longer provide enough force to operate the arms. Replacing the gears with new ones will fix this problem; I've probably done 20 or 30 of them.
Posted on Jun 29, 2007
    Champion:
  • 277 Answers
Check any torn straps broken gear anything stuck between the gear motor is running or trying to (heating up)
Posted on Jan 31, 2006
Carriage does not advance when pressing the space bar or pressing a key. Does advance when depressing tab.
If you press a key does it type or try to correct? The escapement mechanism that allows it to move from space to space may be sticking and causing your problem. That mechanism just may need a flushing and lubrication. You will see a shaft that runs through the carriage. Try to turn it top to rear until it stops. if you hear a click then it has been turned the right amount. If it doesn't turn, then it is as far as it goes. Try hitting the spacebar and see if the carriage moves. If it moves, hit any key and see if it moves. if it moves, hit another key. If it doesn't move then your escapement mechanism needs to either be flushed and lubed or adjusted.
Nov 20, 2015 | IBM Correcting Selectric II
I replaced my color cartridge on my HP Photosmart C3100 series printer and now it is making a grinding sound, but prints perfectly fine - what is the problem?
You would want to try and reinstall the print cartridges. It is possible that something is just stuck that is why you are hearing the grinding sound.
Let me know.
Apr 06, 2010 | HP Office Equipment & Supplies
Scanner carriage jammed #3 and #6 does nothing.
Check if you haven't moved the scanner lock lever accidentally - find the lock lever (used to immobilize the carriage in transport) and move it to locked position, then to unlocked, and power up your unit. Chances are that the carriage was not dislocated when trying to move while locked, and will start to operate.
If it's not that, it may be a number of things, like broken belt, encoder strip (if any), carriage motor fault - things you won't be able to repair yourself.
Nov 12, 2009 | HP Office Equipment & Supplies
System error L1-00
the L1-00 indicate the scanner carriage is not moving. Something is stopping it. Open the document feeder and turn the copier on while watching the scan carriage (beneath the main glass) - does it move or try to move ? does it make a noise?
If it seems to be moving freely for a bit and then stop - is it going back to its "home" position (starting point). Remove the main glass and then move the scan carriage by hand (with the copier turned off) .. does the carriage move ok? check for a loose carriage drive wire or debris or something broken. Make sure the carriage locking screw is not holding it. Then turn the copier back on and see if the carriage makes an attempt to move back to its starting point. if everything seems to be moving ok then the problem could ly with the "home position" sensor. It could also possibly be a bad drive motor.
Apr 03, 2009 | Sharp AL-1655CS Copier
Blinking with L and 1 alternately
the L and 1 indicate the scanner carriage is not moving. Something is stopping it. Open the document feeder and turn the copier on while watching the scan carriage (beneath the main glass) - does it move or try to move ? does it make a noise?
Apr 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Cant move carriage lock lever on the olivetti lettera typewriter.
Try lubricating the lock lever with a drop of Marvel Mystery oil.It should slide from front to rear
Jan 01, 2009 | Olivetti Lettera 35 L Typewriter
Hp7210 showing carriage jam.
  1. Reset your All in One product:
    • Remove the power supply for ten seconds and then, reinsert the power cord and turn on the printer again.
    • Print a basic self test page.
  2. Clean the paper path:
    • Take a look inside the printer to determine the side on which the carriage is located (left or right).
    • If situated on the right, make sure there is no obstruction and then, move the carriage all the way to the left side.
    • If situated on the left, make sure there is no obstruction and then, move carriage all the way to the right side.
    • If located in the middle, ensure there are no obstructions. Then, move the carriage first all the way in one direction and then all the way to the opposite direction. Please do not apply too much pressure.
    • Remove the rear access door from the back of your unit. Check for and remove any paper still in the printer.
    • Replace the rear access door and close your unit top cover.
    • Re-connect the power cable only. If the unit does not automatically turn on, press the Power button.
    • If the Power light is on and steady, print a self test page.
  3. Plug your All in One product directly into another power outlet:
    • Remove the unit power cable from any power strip or surge protectors and plug it directly into a grounded wall outlet
    • Try printing again.
Nov 13, 2008 | HP Officejet 7210 All-In-One InkJet...
EPSON CX7300 locked carriage
hiii...
you carriage is jam at the purge unit..u need to open all u printer cover..try to move the carriage slowly..couse it may can damage purge unit..
Oct 31, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Mp160
Before you try this, put a couple of drops of resin-free oil such as 3 In One (sewing machine oil) or a tiny bit of penetrating lube on the shiny rod on which the carriage rides.
The original lube may have either dried out or has turned into a paste-lube gunk that is making the carriage hard to move.
If the 'rubber band' has teeth on the inside, it is the printhead drive belt and it may be stripped.
If the printhead centers for cartridge changes when opening a cover, let it center, pull the power cord out of the wall and carefully attempt to move the carriage by hand.
If you hear a similar noise, then the belt is stripped and will have to be replaced.
I'm not familiar with your model so can't advise if this is a do-it-yourself job or not.
Jul 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Panasonic AJ-D230H DV/Mini DV VCR Logo
178 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
