Question about Olevia LT37HVS 37 in. LCD HDTV
Backlight Inverter Input Voltage
What should the input voltage be at? Right now with the backlights flickering I have constant 21.4VDC, is that enough or is that low? If the problem is in the backlight inverters do you replace the master or slave or both or how do you know? Any insight would be helpful.
Thanks Aaron
  • 10,594 Answers
Input voltage like 21.4dc is correct and not sure about master or slave inverter board. You have to check one by one. Here is part store offers cheap prices for boards, please ask required boards.
Posted on Sep 06, 2008
Viewpia lcd tv backlight not working
Measure the input voltage to back light inverter board, from the main power regulator board. If it is found OK, replace back light inverter board.
Jul 27, 2012 | Televison & Video
Got sound but no picture on my tv.
Hi.
First check if you have on screen menu and if the problem is still there if you change input source and cables.
If TV has no backlight on all inputs, then it is either inverter not supplying power to the backlight system, or the LCD panel itself. The inverter or the parts connected to the inverter are common cause for the problem. The LCD panel is not a common fault. When problem is the panel the TV is not worth repairing.
When there is an inverter problem the fault is not necessarily the inverter. The technician needs to test the parts to find out what part is responsible. Testing is done tracking voltage from PSU to inverter. Voltage to inverter is usually supplied by the higher VDC line from PSU. Here broad description of how to test the three parts: Before proceeding...
Here replacement parts for most flat panel TV models:ShopJimmy.
See also:
PartStore
Regards.
Ginko.
Sep 20, 2011 | Sanyo DP32746 32 in. LCD Television
Hey Guru- got a question about a Sanyo DP37647. The backlight flickers 1 time when I turn it on and then goes to black, with no backlight. I do get audio. if I turn it off and on a few times, i can get a...
You are right ,the problem is in the backlight. There's a loose connection in the connector of the backlight to inverter or driver.The backlight have high voltage supply,so if the coonector is mildly loosen,it may cause of voltage drop produce and spark and over heat the connector,and totally result of loose connection.So the things you can do to fix the problem ischeck the connection of the backlight.Open the back cover and look the board,located at the center part.It has a metal cover in the board,remove the cover and check the connector of the backlight,Resolder and tightly press the connector to the inverter or driver.It is usually happen to the backlight of the LCD TV.Just fix the connection of the backlight.Try my suggestion and procedure,.Hope it will help you..Thanks..
Aug 29, 2011 | Televison & Video
Screen is like a strobe
Hi.
Problem is inverter, backlight or PSU. The backlight lamps that illuminate the LCD display are flashing. This creates the "kind of strobe" effect that you see. There are several possible causes for the problem.
The lamps themselves are defective. The lamps do not fire up completely and keep flashing. The lamps are not sold alone but they are part of the LCD display. If the lamps are gone the TV is not worth repairing.
The inverter is the high voltage board that supplies the backlight lamps. If the inverter is defective it can still be replaced. Testing is done reading DC in, checking high voltage out, and using an oscillator to test the phase of the AC out signal generated by the inverter oscillator section.
PSU or main controllers may be defective. This will less common in case of flashing back-light. Test this if the inverter is OK and if the problem is DC voltage input to inverter.
Here parts: 42LA30H - ShopJimmy
Regards.
Ginko
Aug 11, 2011 | Proscan 42LA30H 42 in. LCD Television
This morning the power went off briefly. When the power came back on, the monitor screen would not light up. All connections are good, and the power light at the bottom left of the monitor turns green...
Go check the backlight inverter lamp, replace if busted.
This can be found when you open the back of your lcd and manage to get access to it.
The backlight inverter lamp is located at the upper and lower part of the screen.
Go check also the inverter board, the one that suppply high voltage to inverter lamp, see if this ballast transformer are not burnt out.
The input voltage of the inverter board is 24vdc the output is 250v ac..The voltage input terminal of the inverter board usually creates a loose solder. Use a soldering iron to resolder them....
This lamps are available online to order at shoppejimmy.com
Feb 09, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
No picturte just sound
This is a common problem on these plasma TV's. The problem resides in the high voltage boards known as the X and Y Sustain boards.. You can purchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
To test which board is failing, you need to check voltage input to the YSUS board first... Input should be 120V from Power supply, output should be above 250V.. Do this test with XSUS disconnected. IF 250+V exists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Sep 25, 2009 | Zenith Z42PX2D Television
Sound with no picture..backlight working
This failure could be due to a backlight inverter board or the power supply is not providing the 24 volts to it.
The way to fix it is by measuring the voltages from the power supply to the backlight inverter board, if the voltage is present then the backlight inverter board is defective and will need to be replace. If the voltage is lower then 20 volts, then is a power supply failure.
Click here to find the backlight inverter board.
Let me know if you need further assistance. I repair power supplies for all LCD models.
Jul 24, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Olevia 237V Backlight problems
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
I changed my macbook screen, and the backlight now will not work. Everything else works fine, just no light. My real question is what voltage should be coming from the inverter board. I read no AC or DC...
Apple doesn't provide voltage information for the Inverter Board.
If you are getting external video then check to see if there is a dim (un-backlit) image on the display to ensure it is a backlight problem. If so then the chances are good you have a failed inverter board.
Jan 21, 2009 | Apple MacBook Air
Check inverter supply voltage, (should be constant and stable) if found ok, then inverter or back-light tubes are suspected.
Sep 06, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
446 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
