Question about Yamaha YAS-70 Front Surround System Black Theater System
Everything is hooked up correctly, but no sound
I think I have all the cables correctly connected:
  • Speaker cables from the sub to the center system
  • System control cable from the sub to the center system
  • Analog (red and white cables) from the TV to the sub
The system powers up, but the sound is still coming out of the TV instead of the speakers. I've gone through all the input options on the unit, but it doesn't affect anything.
Thanks for the help...
Melinda
Had to run audio out from the Tivo to the Sub. TV doesn't need to be hooked up at all.
Posted on Sep 07, 2008
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
How to connect all components to work
you will have all them all in user manual itself right?
Jun 08, 2008 | Audio Players & Recorders
How do i hook up my samsung hw-h450 wireless audio- sound bar to my pioneer pdp=4280hd
I think your set up is correct. The only other thing you may have to do is to set the sound on your TV to 'External Speaker' (or something similar) from your TV's remote accessing the menu.
Dec 21, 2014 | Pioneer Audio Players & Recorders
Speakercraft v10 subwoofer not taking input signals
Does any other speakers work through the channels you are putting the subwoofer through? Reason i ask is could there be a fault with the channel you are using i.e AUX? is your subwoofer connected with Aux cables or is it a speaker cable? If aux cable is there a slight break in the cable?
Jan 04, 2014 | Audio Players & Recorders
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
The light on my amp is green but no sound
have you got the auto ariel lead from the head unit connected to the remote connection on your amp?
if not then that is your problem, it turns the power on when you turn on the unit. and turns it off when you switch unit off.
hope this helps
Mar 18, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Subwoofer turns on and is hooked up, but no sound.
The signal don't seems to be present to the sub input.
Try change the wire betwen the audio system and the subwoofer.
Spider Guy
Mar 15, 2010 | Onkyo 630-Watt 7.1 Channel Home Theater...
Powers up but no speaker output
Hello montez1599,
That's a great amp.
You do not say what subs you are connecting or what wiring configuration you are using. But there should be no problem if the amp is powering up normally. I'd check the gain and crossover settings to make sure they match the subs.
Having 2 +'s and 2 -'s is just a convenience for connecting more than one sub to the amp. If you have just one sub, connect to either of the positives and either of the negatives (they're connected internally). If you have 2 subs, you can run separate wires to each sub or you can wire the subs together and then run just one positive and negative to the amp.
Hope this helps.
Aug 30, 2009 | Jl Audio 500/1 Car Audio Amplifier
My amp was bad so i replaced it now my sub does not work i checked the wiring that goes from the amp to the speaker and everything seem to be ok then i put another speaker thinking it might be the sub and...
It doesn't sound like the wiring from amp to sub is your problem.
Is your amp getting a power light ?
Are you sure your remote wire is hooked up properly ?
Check both ends of your RCA cables
Jan 05, 2009 | JBL GT150 Car Subwoofer
Subs and amp problems
make sure you have the wires from the amp to the box, and the box to the subs hooked up right... red is positive black is negative
Dec 28, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Open Questions:
See all Yamaha YAS-70 Front Surround System Black Theater Questions
Yamaha YAS-70 Front Surround System Black Theater System Logo
256 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
