Question about Estate TAWS850PQ
Fills but nothing else
The washer will fill itself correctly but then does nothing else. The machine is a little over a year and a half old. I have a feeling the motor is cooked, but the load I had in was a small load. When it does try to move all it does is buzz.
Any ideas?
  • 725 Answers
If you hear a buzz ... is it a motor noise? check if it will drain... if it will drain you problem is the motor coupler ..I can help you replace it get me in a chat.. Hope it helps
Posted on Sep 06, 2008
Beko wmv610 washing machine fills with a little water then stops works on spin drain can eny one tell me the cause thanks
The water level switch (pressure switch) might not be giving the correct signal to washer control board. This causes the washer to switch to drain and empty. It also possible the control board is faulty.
This is a Tesco washing machine and maybe hard to get parts. But if it is under 2 years old you still may have a warranty for it.
Sep 21, 2014 | Washing Machines
The washer fills with water but then nothing happens. The washer does not cycle at all.
I had this happen too; the problem was the lid switch. The plastic housing had come apart, either from the lid being slammed down or just normal wear and tear (the washer is 5 years old). Two small screws on the top inside edge and there was enough slack in the wires where I could pull it out to look; I held it together with my hands, pressed the lever and the washer started cycling as usual. Replacing it is a little bit of a pain but better than buying a new washing machine.
Jul 10, 2010 | Kenmore 22422 Top Load Washer
My kenmore 400 washer fills but nothing else
Lid switch is still most likely the problem. Are you able to unplug washer from wall and check the wire connected to the switch.
Aug 28, 2009 | Washing Machines
Washer fills up but wont switch to agitate
posibble bad timer. if it is skipping over the agitate.
Jun 15, 2009 | Roper RAS8445KQ Top Load Washer
Washer fills but will not spin or agitate? 1 year
Check waste hose not pushed to far down tube.This would cause same problem
Jun 11, 2009 | Washing Machines
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Washing Machine
the main water valve that the fill hoses connect too in the back of the washer is probably bad.
Jul 25, 2008 | Indesit W 123 Front Load Washer
Frigidaire washer machine #FWTBB30DS0
check to see if your drain hose is too far down in the stand pipe this will siphon water out as it fills.
Jan 17, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Washer fills with water , then shuts off , doesn't move to another cycle
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
Jun 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Estate TAWS850PQ Logo
124 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
