Question about RCA P52929 52" Rear Projection Television
SEEING TRIPLE RCA TV MODEL# P52929, SERVICE# P52929YX1, SERIAL# 029551826, CHASSIS# PTK195SB. ANY HELP WILL BE GREATLY APPRECIATED. THE PROBLEM IS- I'M SEEING TRIPLE OF EVERYTHING, I DO HAVE COLOR, AND I DO HAVE SOUND, I'VE TRIED TO MAKE ADJUSTMENTS WITH COLOR AND FOCUS WITH NO HELP. I'M ALSO TRYING TO FIND A SERVICE/PARTS MANUAL FOR THIS TELEVISION.
  • jose-1 Apr 05, 2008
    tring to adjust color focus but red is high in one side and lower on the other side not a striat line to adjust
    New Friend:
Okay first it is a ghost problem and if ur tv is a projection tv then take off the speaker panel located on the front of ur tv. U should see the speakers as well as ur 3projection bulbs well the bottom of them on the projection bulbs there are 2 grey rings on each of them take the grey rings and turn them til that color np longer shows up on ur tv screen as a ghost. U will do this for all the projection bulbs (red green and yellow) thats all u have to do to get the ghosting to go away it also helps to have the bulbs cleaned that will also brighten ur picture as well as keeping u from having to adjust the alighment rings hope thia helps
Posted on Mar 25, 2013
    Problem Solver:
  • 29 Answers
Possible problems: 1. Ghosting is caused by an ingress of off-air signals into the TV through the cable system, or the TV's antenna 2. An F-connector may be loose 3. The cable plant may have a "leak" in the area Solutions: 1. Check and hand tighten the cable fittings to the TV set and VCR. 2. Remove the antenna from the VHF terminals when cable is used. 3. A converter or A/B switch may be needed to correct the problem (A/B switch enables you to bypass the set-top cable box or descrambling cable box and tune all unscrambled channels directly with your TV, antenna, or VCR). good luck!
Posted on Jan 09, 2006
I need the serial number for an RCA 22" tv with DVD model number LED22B45RQD
Its serial number should be with its back cover; either on a sticker or hard printed. If not, can get this information by its chassis inside.
Electro help
Oct 20, 2014 | RCA Televison & Video
My big screen was working and then just turned off and all i get is a click from the power box what do i do to fix this and what parts do i need it is a 52" rca tv model P52929 i really like my tv and dont...
The cicking sound comes from the relay starter . Its like a Fluro tube starter.It is tying to start but because it is damaged can only witch on and off without firing up the display. There may be other parts associated with this when it fails and is not really a DIY job if you are not into electronics
Aug 27, 2009 | RCA P52929 52" Rear Projection Television
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Picture is warped. rca 52 inch model p52929
This is hte beginning of a convergence problem. If you can solder, try resoldering the pins on the convergence ICs. These are large black ICs attached to a heat sink and will be marked STKxxx. If that fails to resolve the problem, replace the ICs.
Keep us posted.
Dan
Aug 25, 2008 | RCA P52929 52" Rear Projection Television
RCA Projection P52937SG Continually changes channels
your model has the PTK195 chassis you can get the service manual and parts at the following link. They email the manual and also provide free tech support to help you with diagnosis.
http://servicemanuals.vstore.ca/
May 03, 2008 | RCA P52937 52" Rear Projection Television
Tv wont come on
do you have a chassis number? example PTK169PGB
CTC169PGB
Mar 26, 2008 | RCA P60921 60" Rear Projection Television
RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
NO POWER, Yes blown fuse.
Was this the 220 ohm in the power supply??? and if the 5 amp blew right away then it probably took out the bridge rectifyer with the power surge that comes alog with hurricane damage to the power lines as I used to live in florida and repaired lots of sets damaged from storms!! After you check the bridge rectifyers I would start looking to find any other shorts. First measure across the ac line with the fuse replaced but not plugedf in . If its shorted check what I mentioned before if its good after you replace the shorted parts you maybe in luck. need more assistance go to sams photo facts download a schematic and we will trouble shoot this together if you post it here so i can look at it. good luck
May 02, 2006 | RCA P52929 52" Rear Projection Television
RCA P52929 52" Rear Projection Television Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
