Would a HDMI cable help a 720p TV? If so what kind?
HDMI cables are the best for HD resolutions. Any kind will work fine since they are all digital cables. They either work or they don't :) I get my HDMI cables here. They are inexpensive and quality.
Posted on Sep 08, 2008
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
My tv won't show what I'm doing on my PS3. I've
Did it work before? What has changed? Do other sources work on the tv such as DVD/Blu-ray player or cable/satellite tv? Believe it or not the type of HDMI cable matters. Look for an HDMI 1.4 cable.
What kind of tv do you have? Can it support 1080p which is the native output of the PS3? If your tv is set to receive 720p it might not work. Make sure it is in autodetect or AUTO. This matters a lot! Let me know which make/model tv you have and we'll troubleshoot further.
Jan 02, 2015 | Video Game Consoles & Games
Hdmi inputs select
This is a 720P TV, please try set up your Samsung DVD play video out put format to 720P, then try it again.
Aug 15, 2017 | Sony KDF-50E2000 50" HDTV
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Good evening, My son has been using his Playstation 3 on a TV with a resolution of 1080p. Now he is trying to use the console on a lower resolution TV. Can you tell me how he can reset his console so he...
OK if hes connecting it to a TV with a red/white/yellow cable then you need to connect it to the 1080p TV again with the hdmi cable but with the red/white/yellow cable on the same tv at the same time. Then in display settings switch it to the red/white/yellow cable setting and thats it. It should be good for the red/white/yellow cable TVs.
If its a TV with hdmi but more like 720p then just use the 1080p tv and go to settings then switch to 720p and there.
Sorry if this is confusing.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have bought a hdmi cable for my 720p samsung tv and it does not work with my Ps3. Any help would be appreciated.
Your TV most likely does not support 720p or you have it setup wrong. the 720p and hp 1040i are very tricky to get set up. Double check everything because if it's set up right then your TV does not support it. Sorry.
Nov 09, 2008 | Video Game Consoles & Games
Problem with component input and 720p HDMI output
does your cable box have an hdmi output? if it does try an hdmi cable instead of componant cables[ i know the hdmi cables aren't cheap] if not, if the reciever has componant outputs, use them instead.
hope this helps
wg
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Televison & Video Logo
Top Televison & Video Experts
