Question about Ovens
3 prong outlet/4 prong plug
The stove I just bought has a four prong plug. Can the plug for the stove be changed to a three prong to fit my outlet?
    Novelist:
  • 166 Answers
If you bought an electric range , it is a 220 volt range with a BIG plug and can only be used in a 220 volt outlet.
If you can plug a small appliance into that outlet then the outlet is only 110 volts and you need an electrician to run a new 220 line!!!!!!
Was the range you are replacing a gas range??? If so that runs on 110 volts like you TV and toaster and every other small appliance in your house!
If you are not sure what you are doing get a professional to help you!
Every year in the United States thousands of people die buy trying to fix the electrical in their home alone!
BEWARE 220 Volts will shock you! BUT USUALLY will kill you if you touch it!
ngafm
Please rate me on this site before you sign off!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!liance in your house!???????????????
Posted on Sep 07, 2008
  • 116 Answers
Hey pcote
The 4plug wiring is for satifying the electrical code (i think 2002) so your wiring need upgrading. The wire on your new unit should be as below
black and red - hots, white - neutral, green - ground. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
You could simply connect only the black, red and white for your 3 wire system. Often new units have an internal metal ground strap (green wire) that can be tied to the white (neutral) in a 3 wire system.
Regards
Hotpoint oven manual
I found that GE offer a specific plug which allows four connections:
Universal range power cord (4W / 4' / 40A) WX09X10035
You may need to find out if you have such a socket or how to produce such a socket.
Dec 18, 2013 | Ovens
I just bought a new whirlpool stove and it had a 4 prong plug and my outlet only has three can i just switch the plug
Jeff Hi where are you located ? that almost sounds like a stove from over seas ?
I can't understand why you would have a plug like this on a GAS type stove ? give me some more infomation
Dec 03, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Kenmore Elite stove and the broiler element will not heat up, the element it's self is okay
number 1 unplug unit inspect the outlet which element plugs into you will see prongs that clip onto element make sure there not burnt thoes prongs are in ceremic caseings make sure they not broken or chiped causing a bad connection i hope that helps
Apr 08, 2010 | Kenmore Ovens
I am replacing a 4 prong cord which is red, white, black, green with a 3 prong all black cord. My stove is a Maytag which was originally wired with a 4 prong pigtail for use in a trailer. I want to replace...
Okay, without knowing everything I would need to know; here's what I propose you do. First of all, are you exchanging the same wire size cord (eg. #12 stranded wire for 20 amp, and #10 for 30 amp, #8 wire for 40 amp,  # 6 for 50 amp, and so on) for the same application (ie. 30 amp for dryer, and 50 amp for range, etc.) ?  Let's say you are, so what you want to do is take the 4 prong off (one by one), and write down the configuration and color, as you take off each wire. And then you're going to apply this to your 3-prong plug. So, without seeing the plug and its application - I'm going to explain to you how to wire this. First, put the black (hot leg) wire will go on one of the straight prongs - and the red (the other hot leg) wire will go on the other straight prong. Now cut the white wire down to about an inch, so it can fit into the plug when you're putting the cap back on. And remember to tape this white wire with electrical tape. This is for many reasons, but its basically for safety. Now, the remaining wire (green) goes to the right-angled prong - which is your ground wire. Now your wired for 240 volts, and depending on the size of the wire - your wire size shall be in accordance with the amperage that I explained earlier. Now make sure that your power is off at the panel before you plug this oven plug into the wall. Then, turn the breaker on, then off. If everything seems okay, plug the cord into the wall (with the oven off) - and then turn the breaker back on. Then proceed to turn your oven on from there, and then if everything checks out okay, then your good to go. Good Luck with this, and I hope this works out for you. If not, feel free to contact me again. - Jim
Apr 05, 2010 | Ovens
I have a four wire cable for electrical oven in
On 4 wires one is Ground, one is common, The other 2 are line voltage 110-130 VAC. Ground and Common serve the same purpose. Change the cable with the plug to match the outlet in the home ( get the cable off your old stove). Be sure the plug is out of the outlet. Hook up as in old stove.
If you do not feel confident get an electrician so you do not get hurt on burn down you home.
Sep 19, 2009 | Whirlpool RBS245PDS Electric Single Oven
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
Frigidaire self cleaning stove mod FEF369cgsb ser vf94422321 was originally wired direct and it shows 4 wires. Now I want to use a plug and outlet, 3 prong. How do you connect the 3 prong plug? thank you...
Vivian
the original wiring probably had a red, white, black, and green wire. It is 240 volts. The red is hot, carrying one leg of 120 volts. The black is also hot, carrying 120 volts. The white is neutral, and the green is the ground.
I am against altering this, but you can wire the red and black each to a hot leg, and wire the white and green to the bottom ground. This then introduces a ground wire to your neutral bar in the circuit panel, which is not the best way to do it, but will work.
Best to get an electrician to wire a 4 wire cable to a four prong outlet, and then use a four wire pigtail with a 4 pronged plug.
Lots of people modify it, they ground the green wire to the stove, where the wire originates,and to the box with the outlet in it where it hooks onto the plug if it is metal. Then you have a part ground. And that is assuming you have a cable with wires sticking out to wire to a plug.
Boils down to your decision. If the above isn't the case, get a four pronged outlet and wire the red and black to the top two prongs, the white to the neutral, and the green to the metal box it sits in.
Sirwriter
May 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Going from gas to electric how do i install it
you will require a 40 amp breaker and 8/3 wire with ground which totals 4 wires and requires a 4 wire outlet.
make sure you purchase a receptacle that fits the plug on your range.
please mark this answer as a fixya! thanks
Mar 06, 2009 | Ovens
110v Range cords
Most duel fuel ranges need 220 volts. and the outlets are different.
If you can't find a heavy standard real range cord it is because in your area they probably changed the code. Try ordering out of state from Home Depot E bay etc. Or change the outlet.
Jun 16, 2008 | Ovens
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Ovens Logo
394 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
